Viz Arc User Guide
Version 1.7 | Published November 15, 2022 ©
System Requirements
This page describes the minimum software and hardware requirements for Viz Arc.
Minimum Software Requirements
The following are minimum software and version requirements for Viz Arc to function properly:
General
  • Windows 10/11
  • Microsoft .NET Core Framework 6.0
  • CodeMeter version 6.80 and later
Vizrt Software
  • Viz Engine/Artist 3.14.x: Must be installed as a Video machine and shared memory output must be configured for built-in Viz Output to function.
  • Graphic Hub 3.5.0
  • Graphic Hub REST 2.5.0
Note: To integrate with Viz Virtual Studio, Tracking Hub 1.1 or higher must be installed.
Epic Games Unreal Engine
  • Unreal Engine 4.26 or higher is required for Unreal integration.
Minimum Hardware Requirements
Viz Arc runs on the following platforms:
  • Windows 10/11 (64-bit only)
  • Windows Server 2012 R2
For optimal performance, use the pre-installed Windows image from Vizrt. You can obtain Windows image files from your local support office.
The following prerequisites apply to all platforms. Applying the changes may require local administrator access rights, new or amended group policy entries, or modified services. Contact your local IT manager for assistance.
Please refer to the relevant Viz Engine version hardware requirements.
