Viz Arc User Guide
Version 1.7 | Published November 15, 2022 ©
Keyboard Shortcuts
To access the Keyboard Shortcuts configuration menu, select the Keyboard Shortcuts icon on the left of the window in the Config panel.
Keyboard Shortcuts
Keyboard Shortcuts are divided into three sections:
images/download/attachments/62209212/image2020-4-3_17-16-48.png
System Shortcuts
images/download/attachments/62209212/image2020-4-3_17-18-36.png
System Shortcuts apply operations that are are global to the Viz Arc system, such as Open Project, Save, Undo, Redo, etc. System operations that can be controlled with keyboard shortcuts are listed at the top of the window. It’s possible to change the default shortcut for an existing system action, remove the shortcut, or reset it back to default.
Custom Keyboard Action Shortcuts
images/download/attachments/62209212/arc_ks_ckas.jpg
Action Shortcuts are used to assign a key or combination of keys to execute actions. This menu contains a list of all actions that have a keyboard shortcut assigned and the action box color for the action.
It's possible to assign keyboard shortcuts to any Action in a project and to assign the same keyboard shortcut to more than one action.
You can add Custom Action Shortcuts directly from this window.
Custom Stream Deck Shortcuts
images/download/attachments/62209212/arc_ks_css.jpg
Custom Stream Deck Shortcuts are used to assign an action (or group) to a specific Stream Deck button (if connected). This menu contains a list of all actions that have a keyboard shortcut assigned and the action box color for the action.
images/download/attachments/62209212/arc_ks_streamdeck.jpg
Note: All action shortcuts are stored as part of the project.json file. For more details, see Files and Folders.
To Manage Shortcuts
images/download/thumbnails/62209212/arc_ks_edits.jpg
  1. Click on the Shortcut item.
  2. Enter the desired key combination on your keyboard.
To Remove Shortcuts
Press the Trash can images/download/thumbnails/62209212/arc_ks_rems.jpg icon next to the related shortcut.
To Reset Shortcuts to Default
Press the Reset images/download/thumbnails/62209212/arc_ks_ress.jpg icon next to the desired shortcut (for system keyboard shortcuts only).
To Add Custom Action Shortcuts
There are two ways to add an action shortcut:
  • Config Window
  • Action Window
Config Window
images/download/attachments/62209212/arc_ks_conf.jpg
  1. Click the Add button in the Config > Keyboard Shortcuts menu.
  2. Select an action from the available options. A new Action row appears in the window.
    images/download/attachments/62209212/arc_ks_action.jpg
  3. Click on the shortcut area and press the desired keyboard shortcut. It's possible to add both Keyboard and Stream Deck (if available) custom shortcuts.
Action Window
images/download/attachments/62209212/arc_ks_actionw.jpg
In the action Edit menu, click on the shortcut area and press the desired keyboard shortcut. It will automatically be added to the Custom Keyboard Shortcuts list.
