The following shortcuts are valid for the Asset View:
Action  | Default Key and/or Mouse Shortcut  | Configurable  |
Renames an item  | F2  |
Focuses on the search input field  | CTRL + F  |
Copies the UUID of the item to the clipboard  | CTRL + U  |
Copies the path of the item to the clipboard  | CTRL + SHIFT + U  |
Checks in an item  | CTRL + I  |
Checks out an item  | CTRL + O  |
Adds a new scene or classic material (if the type is selected)  | CTRL + N  |
References search on this item  | CTRL + R  |
Exports file (if supported)  | CTRL + E  |
Increases Icon Size  | CTRL + +  |
Decreases Icon Size  | CTRL + -  |
Copies  | CTRL + C  |
Cuts  | CTRL + X  |
Pastes  | CTRL + V  |
Shows icon view  | CTRL + SHIFT + 1  |
Shows list view  | CTRL + SHIFT + 2  |
Shows detail view  | CTRL + SHIFT + 3  |
Selects all items  | CTRL + A  |
Shows properties  | CTRL + P  |
Duplicates file (needs to be copied first)  | CTRL + SHIFT + V  |
