General
Function  | Key and/or Mouse Shortcut  | Configurable  |
Shows Object Editor  | CTRL + 1  |
Shows Dopesheet View  | CTRL + 2  |
Minimize Spline Editor Height  | SHIFT + PAGE DOWN (on stage view focus)  |
Increase Spline Editor Height  | SHIFT + ↑  |
Decrease Spline Editor Height  | SHIFT + ↓  |
Shows Spline View  | CTRL + 3  |
Maximize Spline Editor Height  | SHIFT + PAGE UP (on stage view focus)  |
Shows Dope/Spline View  | CTRL + 4  |
Stage Tree
Jumps to Top Container  | HOME  |
Jumps to Last Container  | END  |
Moves a page down in the tree  | PAGE DOWN  |
Moves a page up in the tree  | PAGE UP  |
Scrolls up the tree  | UP ARROW (↑)  |
Scrolls down the tree  | DOWN ARROW (↓)  |
Jumps to an item (Director, Actor, or Channel), in the tree  | Press the first letter of the item name  |
Opens or closes the selected tree  | + or RIGHT ARROW (→)  |
- or LEFT ARROW (←)  |
Group Directors  | SHIFT + D  |
Ungroup Directors  | CTRL + SHIFT + D  |
Delete Selection  | DEL  |
Timeline
Animation
Starts Animation  | ENTER  |
Starts Animation Backwards  | SHIFT + ENTER  |
Start Animation ignoring Stop points  | CTRL + ENTER  |
Start Animation ignoring Stop points Backwards  | CTRL + SHIFT + ENTER  |
Pause/Continues Animation Forward  | SPACE  |
Pause/Continues Animation Backwards  | SHIFT + SPACE  |
Pause/Continues Animation ignoring Stop points  | CTRL + SPACE  |
Pause/Continues Animation ignoring Stop points Backwards  | CTRL + SHIFT + SPACE  |
Timeline
Sets timeline to 0  | HOME  |    |
Sets View to End Director  | END  |
Set View to Time-line Start and move Marker  | CTRL + HOME  |
Sets Time-line Marker/Value to End (not when infinity is selected)  | CTRL + END  |
Set View to Time-line Start, Zoom Region  | SHIFT + HOME  |
Set View to Time-line End, Zoom Region  | SHIFT + END  |
Set View to Time-line Start, Zoom Region and move Marker  | CTRL + SHIFT + HOME  |
Set View to Time-line End, Zoom Region and move Marker (not when infinity is selected)  | CTRL + SHIFT + END  |
Move Timeline Marker  | ←/→ In 1080i50 format, moves the time-line marker five fields, left or right, and in 1080i60 the movement is six fields, left or right.  |
ALT + ←/→. In 1080i50 format, moves the time-line marker 50 fields, left or right, and in 1080i60 the movement is 60 fields, left or right.  |
CTRL + ←/→. Moves the timeline 1 filed left or right.  |
Moves Time-line Marker to nearest Key Frame  | J  |
Brings View to Time-line Marker  | M  |
Jumps to next Key Frame  | TAB (a Key frame must be highlighted first)  |
Jumps to previous Key Frame  | SHIFT + TAB  |
Deletes Selected Key Frame(s)  | DELETE  |
Tween Mode (Director Scalemark)  | T + start/end click on the timeline   |
Zooming
Pans View  | Middle mouse click and drag  |
Zooms Time Axis In or Out  | Mouse wheel  |
Z + Middle mouse click and drag  |
Zooms Time Axis to Selected Channel, keep Spline view  | SHIFT + Z  |
SHIFT + Y  |
Zooms Time Axis to whole Animation, keep Spline view  | SHIFT + X  |
Zooms Spline/Dopesheet View In  | Mouse wheel  |
Z/Y  |
CTRL + Plus sign on the numeric keypad  |
Zooms Spline/Dopesheet View Out  | Mouse wheel  |
X  |
CTRL + Minus sign on the numeric keypad  |
Zoom Splineview in (Drag middle Mouse button to adjust)  | A  |
Zoom Splineview out (Drag middle Mouse button to adjust)  | S  |
Zooms Spline View to whole Spline  | SHIFT + A  |
Zooms Time Axis and Spline View to view all Key Frames of selected Channel  | SHIFT + Q  |
Zooms Time and Value Axis to View All Key Frames  | SHIFT + W  |
Zooms in onto specific region  | X + Drag mouse rectangle  |
Y + Drag mouse rectangle  |
Zoom Timeline to selected Key Frames  | SHIFT + C  |
Searching
Open/close Keyframe Search  | CTRL + F  |
Jump to first keyframe search result  | CTRL + H  |
Jump to last keyframe search result  | CTRL + E  |
Jump to next keyframe search result  | CTRL + N  |
Jump to previous keyframe search result  | CTRL + P  |
Keyframes
Provides Rubber band Selection  | R + Left mouse click and drag  |
Copies Selected Key Frame  | C + Left mouse click and drag  |
Reverses the Order of Selected Key Frames  | CTRL + R  |
Insert Stop Point  | P + Left Mouse button click on Director Bar  |
Insert Keyframe  | INS + Left Mouse button click on Spline View  |
Invert Order of selected Keyframes  | CTRL + R  |
View
Switch timeline to seconds  | CTRL + 8  |
Switch timeline to frames  | CTRL + 9  |
Switch timeline to fields (on interlaced formats only)  | CTRL + 0  |
Snaps to Grid on/off  | CTRL + G  |
Show spline 1  | 1  |
Show spline 2  | 2  |
Show spline 3  | 3  |
Switch Keyframe info on/off  | CTRL + I  |
Escapes from moving a Key Frame  | ESC  |
