General Shortcuts
Function  | Default Key and/or Mouse Shortcut  | Configurable  |
Moves to Top Container  | HOME  |
Moves to Last Container  | END  |    |
Moves to top of page  | PAGE UP  |    |
Moves to bottom of page  | PAGE DOWN  |    |
Scrolls up the Container list  | UP ARROW (↑)  |    |
Scrolls down the Container list  | DOWN ARROW (↓)  |    |
Opens Container tree  | RIGHT ARROW (→)  |    |
Closes Container tree  | LEFT ARROW (←)  |    |
Opens plug-in panel  | +  |
Basic View Controls and Shortcuts
Inserts New Container  | CTRL + INSERT (The new Container is created above the first selected Container.)  |
Rename Container  | F2  |
Multiselects Containers  | CTRL + Left click  |
Deletes selected Container(s)  | CTRL + DELETE  |
Opens whole Tree  | CTRL + O  |
Opens Subtree  | ALT + +  |
ALT + RIGHT  |
Collapses whole Tree  | CTRL + I  |
Collapses Subtree  | ALT + -  |
ALT + LEFT  |
Locks selected Container(s)  | CTRL + L  |
Unlocks selected Container(s)  | CTRL + SHIFT + L  |
Groups selected Container(s)  | CTRL + G  |
Ungroups selected Container(s)  | CTRL + SHIFT + G  |
Hides selected Container(s)  | CTRL + H  |
Shows selected Container(s)  | CTRL + SHIFT + H  |
Searches Container  | CTRL + F  |
Copies selected Container(s)  | CTRL + Left click on container name and drag  |
Copies selected Container(s) to Clipboard  | CTRL + C  |
Pastes Containers from Clipboard  | CTRL + V (They are created one hierarchical level underneath selected container.)  |
Cuts selected Container(s)  | CTRL + X  |
Moves selected Container(s)  | Left click on container name and drag  |
Moves selected Container and retain transformation properties  | ALT + Left click on container name and drag  |
Copies Properties of Container  | Left click on container Properties and drag  |
Merges Group  | CTRL + M  |
Splits Container  | CTRL + SHIFT + M  |
Plug-in Overlay
Function  | Key and/or Mouse Shortcut  | Configurable  |
Opens plug-in Panel  | +  |
Selects plug-in  | Cursor Keys  |
Selects plug-in and applies to selected container(s)  | ENTER  |
Leaves plug-in Overlay  | ESC  |    |
