Function | Key and/or Mouse Shortcut | Configurable |
Opens Shortcut list | CTRL + F1 |
Sharpens Edge of Selected Point or Points | SHIFT + Left click | |
Deletes Selected Point(s) | DELETE | |
Adds New Anchor Point | Left click |
Adds new Bezier point | Hold Left mouse button down and drag |
Creates New Spline | INSERT + Left click | |
Opens/Closes Active Spline | C | |
Closes Spline | Click on the first point to toggle open / closed |
Enables/Disables Spline Info | H | |
Moves Active Spline | ALT | |
Copies | CTRL + C | |
Cuts | CTRL + X | |
Pastes | CTRL + V | |
Selects Point or Spline | S | |
Moves Anchor point | CTRL + Left mouse button | |
Moves handles | CTRL + Left mouse button | |
Moves single handle | SHIFT + Left mouse button | |
Removes an Anchor point | Click on existing point with Left mouse button |
Provides Rectangular selection | Hold S + Left mouse button down, and drag |
Converts straight point to Bezier | SHIFT + Left mouse button drag on point | |
Tip: Make sure the Handle Event () button is turned off to allow the shortcuts to work.
