Matrox X.mio5
The Matrox X.mio5 video board is the next generation IP card supporting SMPTE ST 2110-20/30/40 protocols. It is equipped with quad 25GbE SFPs delivering an effective, fully redundant bandwidth of 50GbE, capable of providing four UHD inputs and outputs.
Important: The final models of X.mio5 won't have a genlock connector. Cards must be sync'd to PTP.
General Notes
Please be aware that a xMIO5 uses a 16xPCI slot. It can't use the same slot as a xMio3.
To make sure the PTP is stable, all Power Management options in Windows and BIOS need to be disabled. ("runtime power management" disabled in BIOS settings)
xMIO5 boards require two IP adresses. This is mandatory.
Viz Engine with xMIO5 is officially JT-NM Tested (April 2019) (https://jt-nm.org/jt-nm_tested/)
Key Features
Native SMPTE ST 2110 support with no CPU usage.
4x UHDp60/50 inputs and outputs over 25GbE.
ST 2110-21 packet pacing in hardware for narrow senders (Type N).
Wide asynchronous receivers (Type A).
32x HD inputs and outputs over 25GbE.
256 audio flows from one to 64 tracks.
Multi-channel HDR conversion.
On-board de-interlacing, scaling and compositing.
Integrated hardware PTP for ST 2059-2.
Built in NMOS IS-04 and IS-05 support.
Matrox X.mio5 Configuration
Please see section SMPTE ST 2110-20/30/40 Configuration for further details.
