Introductions and Notations
By default Mosart organizes all templates in a single file, C:\ChannelTemplates\channeltemplates.xml. The template database makes it possible to store the templates in a MySQL database. The main benefits for this is follows:
  1. To share templates among Mosart installations and galleries.
  2. To provide synchronized template sets between Mosart main and backup servers.
Viz Mosart Template database tables
Table name
Prefix
Short description
db_database
db
Mosart Template Database update table. Contains an overview of database update.
em_enumerationmember
em
The enumeration members that may be used as values for template fields of enumeration type.
en_enumeration
en
The enumerations that may be used as types (i.e. sets of admissible values) for template fields.
fi_field
fi
The fields used as template inputs.
ga_gallery
ga
The galleries.
lo_lock
lo
Contains locks for editing database content.
sq_sequence
sq
Contains sequences stored as part of the Mosart template sets.
ta_templatetypealias
ta
The template type aliases (a template type may be referred to by several aliases).
td_templatedescription
td
The template descriptions. Input fields and transition input fields. A template may have different descriptions for different galleries.
tdfi_connection
tdfi
Relation, relating template description and fields.
te_template
te
The templates.
ti_templateimplementation
ti
The template implementations. A template may have different implementations for different galleries.
tr_transition
tr
Available transitions to be applied between templates.
ts_templateset
ts
The template sets (the templates are organized in sets).
tsp_templatesetproperties
tsp
Template set properties
tt_templatetype
tt
The Mosart template types.
Conventions and notations
Table prefix
Each table has a unique prefix consisting abbreviating the rest of the table name followed by an underscore (_). This prefix is used both in the table name and for all columns in the table. Using the prefix helps identifying relationships between column names and tables.
Syntax :
Table
<prefix>_<tableName>
ts_templateset
Column
<prefix>_<columnName>
ts_recno, ts_name
Foreign key
<prefix>_<foreignColumnName>
ts_ga_recno
Primary keys
Each table has an integer column …_recno (with … representing the prefix, except the _) representing an Primary key, and thereby as value of foreign keys, where applicable.
Foreign keys
A foreign key (referencing a …_recno column of some table) usually has the name …_…_recno (with the two …s representing the prefixes, still except the _, of the containing and referenced tables, respectively). (In the case that one table has more than one foreign key to the same table, other names have to be invented.)
Data types
The following data types are used in this specification:
Type
Comment
datetime
Data type capable of storing a point in time (date and time of day).
varchar( n )
Variable length string.
integer
General integer.
smallint
Small integer, normally used to store boolean values (0=false, 1=true).
longtext
Data type capable of storing a Unicode string of virtually any length.
Fixed columns
Every table contains the following four fixed columns to store update and insert information for the individual rows. Note that these columns are not stated in the forthcoming table descriptions.
Name
Type
Allow Null
Description
<prefix>_inserteddate
datetime
No
The point in time at which the row was inserted.
<prefix>_insertedby
varchar(32)
No
Mosart server responsible for the insert. Given by AvAutomation TemplateDbDefaultInserter property.
<prefix>_updateddate
datetime
No
The point in time at which the row was last updated (or inserted).
<prefix>_updatedby
varchar(32)
No
