ga_gallery
The table ga_gallery contains all Mosart galleries using the database.
Note: In Mosart AvAutomation the property ThisGallery shall reflect the gallery name as stored in the ga_name column.
Name
Type
Allow Null
Description
ga_recno
integer
No
Primary key.
ga_shared
smallint
Yes
Set to true (1) for the shared gallery. The shared gallery may be used by clients to obtain all shared template sets within the database. Only one gallery shall be used as the shared gallery. By default, a virtual gallery named SHARED is used for this purpose.
ga_name
varchar(32)
No
The gallery name.
ga_description
varchar(128)
Yes
Optional gallery description.
ga_avconfigxml
longtext
Yes
The XML formatted contents of the avconfig.xml file used in this gallery.
ga_ts_recno
integer
Yes
Optional foreign key referencing the ‘default’ template set of the gallery.
ga_dbversion
string
Yes
The database version used by the Mosart applications for the gallery. This database version reflects the current Mosart version.
Note: One row only should have ga_shared = 1. The name of this gallery is by default set to ‘SHARED’. All shared templates belong to this gallery.
