Mosart Web Applications Guide
Version 1.7 | Published March 11, 2024 ©
Setup and Administration
Setting up the Rundown Viewer
Prerequisites
Viz Mosart 5.1.0 or later
Perform all three procedures, Download, Installation and Configuration.
Download
Collect the latest software bundle from Vizrt's customer FTP at https://download.vizrt.com/
by navigating to / products/VizMosart/Latest Version/WebApplications/.
Note: If upgrading, make sure an existing instance of the Mosart Web Applications Configuration Tool is not open.
Installation
The Mosart Web Applications bundle shall be installed on the Viz Mosart server.
Run the downloaded file MosartWebApplications.Bundle-n.n.n.n.exe.
The web applications that will be installed are listed.Note: The Installer places two applications on the local machine
Vizrt Mosart Web Applications
Vizrt Mosart Web Applications Configuration Tool
Click Install.
Any previously installed versions of the Mosart Web Applications are automatically upgraded. -
After successful installation, a Mosart Web Applications Configuration Tool automatically displays.
Note: A desktop shortcut to Mosart Web Applications Configuration Tool is added by default.
Configuration
Ensure that your Viz Mosart system is operating under normal working conditions.
As a minimum,-
ManusAdmin must be running.
The Viz Mosart UI is running, displaying a rundown.
From the Viz Mosart Web Applications Configuration Tool, in the Rundown Viewer panel, click Open.
The Rundown Viewer automatically displays in your default web browser.
Additional Server Settings
Web server hostname
At startup, the Configuration Tool attempts to autodetect the web server hostname and if successful, pre-populates the field.
For some setups, the Configuration Tool's web server pre-populated hostname will differ from the f ully qualified domain name (FQDN). For example, the hostname gets automatically pre-populated as web-apps, yet the FQDN is web-apps.example.com.
To enable network communication with Mosart Web Apps
You can enable other machines on the network to reach Mosart Web Apps .
From the Configuration Tool menu bar, click the Settings (gear) icon.
The Server Configuration menu appears.
In Web server hostname, enter the FQDN.
Click Save.
Enabling HTTPS
The Web Applications suite optionally supports HTTPS authentication for the applications running under it, with a centralized interface to help with certificate configuration.
Note: Depending on the application, some additional configuration may be needed in the connected applications (for example Viz Mosart itself) to enable HTTPS communication.
Step 1 - Activate HTTPS in Mosart Web Applications
Launch the Viz Mosart Web Applications Configuration Tool (a desktop shortcut is usually available by default).
In the top right corner, select the Settings (gear) icon.
The Server Configuration menu appears. -
Select Use HTTPS.
Note: This selection turns on HTTPS for the NRCS Plugin, Mosart Timing Display and Rundown Viewer.
Provide certificate, key and authentication details (consult with your IT department to obtain this).
Click Save.
Step 2 - Turn HTTPS on in Mosart Remote Dispatcher Service
Copy the file "C:\Program Files (x86)\Mosart Medialab\Mosart Server\ConfigurationFiles\RemoteDispatcherServiceConfig.xml" to "C:\ProgramData\Mosart Medialab\ConfigurationFiles".
Fill in the following fields, using the same three values from the HTTPS Configuration menu shown above :
SignalRUseHttps: true
SignalRCertificatePath: <Certificate File entered above>
SignalRCertificateKeyPath: <Private Key entered above>
SignalRCertificatePassword: <Password entered above>
Restart the Remote Control Service.
Troubleshooting
Web Apps Service reports as offline
At any time you can start the Mosart Web Applications Configuration Tool and check operating status.
A common error is when a Windows service has failed.
Try restarting the service with the Restart button.
You can also rewrite any previously entered values with the Reconfigure button.
Bypass the Mosart Web Applications Configuration Tool to access Web Apps
In failure situations, you can use your web browser to communicate with the Mosart Web Apps (instead of the Configuration Tool).
NRCS Plugin
From the Configuration Tool, copy the NRCS link (click Copy).
The URL has the form similar to: http://<your-hostname>:55142/plugin/?nrcs=ENPS&mosid=mosart -
Open you web browser and paste the URL in to see the NRCS Plugin.
Rundown Viewer
Edit the URL to: http://<your-hostname>:55142/rundown
Timing Display:
Edit the URL to: http://<your-hostname>:55142/timingdisplay/editor
