Scheduled Recording
Channel Recorder has its own scheduler to plan recordings in the future.
The command to record an input signal starting at 12:00 and running for one hour would be the following:
RECORD SET scheduled.mxf IN=12:00:00:00 OUT=13:00:00:00
If a scheduled recording is being interrupted by a loop or crash recording, the following logic applies:
  • A recording is being issued while a scheduled recording is running: The scheduled recording will be interrupted and stopped.
  • During loop recording someone decides to schedule a recording in the future: The recording will be scheduled and run when/if the loop recording stops before the specified time, otherwise it will fail.
