Tracking Hub
Version 1.1 | Published December 03, 2018 ©
Configure the Studio
This section details how to configure the Virtual Studio.
images/download/attachments/41795058/setup_studio_menu.png
  1. Click Open to select a previously saved studio configuration, or create a new configuration by clicking Save As.
  2. Set the Frequency frame rate:
    • 50 Hz
    • 60 Hz
    • 59.94 Hz
  3. Set the Synchronization base:
    • Freerun: No synchronization. Tracking Hub runs using its own time base, corresponding with the configured frequency. Should not be used in production environments.
    • AV-Card: For Plura PCL-PCI and PCL-PCIe sync cards.
    • Viz Engine: Synchronized with Viz Engine, running on the same computer.
  4. Go to Configure Topology.
