Tracking Hub
Version 1.1 | Published December 03, 2018 ©
Topology Panel
The Topology Panel shows a representation of the tracking systems, the connection to a Viz Engine and which Viz Engine services are in use.
images/download/attachments/41794790/installation_topolgy.png
Tracking Systems
The Tracking System panel represents the tracking software in the studio.
Click on a tracking system icon to view its properties (see Parameter Panel).
A line from the tracking system represents a connection to a Rig.
images/download/attachments/41794790/setup_tracking_panel.png
Right-click Menu:
images/download/attachments/41794790/setup_track_connect.png
  • Connect to: Connects to a Rig.
  • Connect/Disconnect: Connects to or disconnects from the tracking system.
  • Analyze timing: See Analyze Time.
  • Analyze rawdata: Enables or disables the collection of raw data for analytical purposes.
  • Delete: Removes the Tracking System.
    Right-click on a Bar:
images/download/attachments/41794790/setup_track_right_click.png
  • Reset bar’s min/max: Resets the minimum and maximum value of each bar.
  • Reset spectrum’s min/max: Resets the minimum and maximum value of the whole spectrum and each bar.
Rigs
images/download/attachments/41794790/setup_rigs_panel.png
A Rig is the interface between the Tracking System and the Viz Engine. Click on any Rig icon to view its properties (see Parameter Panel).
A line from a Rig on the left represents a connection to a tracking system (see Tracking Systems). A line from a Rig on the right represents a connection to a Service (see Services).
Rigs are defined as the following types:
  • Translation
  • Arm
  • Location Pivot Rotation
  • Pivot Rotation
  • Camera
  • Object
    The Translantion rig is for position data only, and provides the Tracking Hub with the following parameters:
  • pos_x
  • pos_y
  • pos_z
    The Arm rig can be rotated in 3 dimensions, and starts with a swivel. It has a defined length with a defined direction, and offsets between swivel and length.
Both the Translation and Arm rigs are used for camera systems such as Spidercam:
images/download/attachments/41794790/panels_20151030_143540.jpg
The Location Pivot Rotation rig is a rotation interface in the X-Z dimension, with center point (0/0).
Pivot Rotation is a rotation rig with a definable center point. The rig provides the Tracking Hub with the following coordinates:
  • pivotx
  • pivoty
  • pivotz
    Camera is a basic rig for tracked cameras.
Object is a basic object for tracked objects.
Services
A Service is the element of a Viz Engine which is connected to the Tracking System through the Rig.
Click on a Service icon to view its properties (see Parameter Panel).
A line from the a Service represents a connection to a Rig (see Rigs).
images/download/attachments/41794790/setup_camera_panel.png
Services available are:
  • Camera: Tracks a camera for Viz Engine .
  • Object: Tracks an object with Viz Engine.
  • Parameter: Provides all required data for the creation of the 3d View.
  • MoCap: Captures motion for Viz Engine.
  • Communication Timing: Sends timing information which are measured during tracking data acquisition.
  • Tracking Timing: Sends timing information which are measured during sending the data as service to the engines.
    Right-click displayed object for additional menu:
images/download/attachments/41794790/setup_service_right_click.png
Topology Connection Lines
The Topology Connection Lines show the connections between each item in the Topology. Double-clicking a Topology connection line between a Tracking System and a Rig opens the Tracking parameter routing window for the connection:
images/download/attachments/41794790/setup_cross_parameters.png
Topology Colors
The colors of the icons in the Topology view show the working condition:
  • Green: Everything is OK and in regular working condition.
  • Grey: The tracker is not connected or deactivated.
  • Orange: The Service or Tracker state is in warning condition. See the log or message for more information.
  • Red: The Tracker or Service is in a serious error state. See log or message for more information.
Motion Capturing with Motion Analysis
Motion Capturing is a special way of collecting and forwarding data to an engine.
There are no camera positions transmitted, but the movements of a person.
For these special procedures, there's a new rig and a new service available.
Selectable via the menu:
Rigs --> Add MoCap
Services --> Add mocap service
images/download/attachments/41794790/image2018-7-3_12-47-3.png
Connect the MA Tracking System to the MoCap Rig as usual.
images/download/attachments/41794790/image2018-7-3_13-22-41.png
In this case, there is just one axis available.
images/download/attachments/41794790/image2018-7-3_13-24-17.png
Name of the axis is depending on the used name in MA's Cortex.
Mocap Service can be used as other services.
