Tracking Hub
Version 1.1 | Published December 03, 2018 ©
Use of Templates
You can use templates for an easy and fast configuration of several studios. There are several pre-made templates available in C:\ProgramData\vizrt\VizTH\.
You can also create your own templates. However, you must copy them to the Tracking Hub directory on a new installation.
Using existing Templates
  1. Go to Tools → Create System From a Template.
    images/download/attachments/41795032/image2017-12-11_13-1-14.png
    This opens a new window where you can select a predefined template:
    images/download/attachments/41795032/image2017-12-11_13-7-18.png
  2. After clicking create, you get a complete system consisting of at least one Tracking System, one rig and one service. Depending on the template, it can include several Tracking Systems and rigs. images/download/attachments/41795032/image2017-12-11_13-20-9.png
  3. Configure the individual settings as applicable:
    • Interface of the tracking system.
    • Set the correct Com or UDP port.
    • Insert the correct IP address for the Viz Engine.
Creating own Templates
If you want to reuse a complete system, you can create your own template for it.
  1. Go to Tools → Make Template.
    images/download/attachments/41795032/image2017-12-11_13-35-12.png
    This opens a new window where you can select the parts for your template:
    Important!
    Do not select Parameter in the Services column!
    images/download/attachments/41795032/image2017-12-11_13-38-15.png
  2. When you have seleted you items, click Create Template and enter a name for the template. Then click Save As.
    This saves a new template in the C:\ProgramData\vizrt\VizTH\Templates directory, in a file called XML_TH_Temp_your_name.xml.
