Tracking Hub
Version 1.1 | Published December 03, 2018 ©
Words and terminology
Some commonly used words and terminology are described in this section:
Term
Definition
Virtual Studio
The real-time combination of people or other real objects and computer generated environments and objects in a seamless manner.
Viz Virtual Studio
A solution to create and manage virtual studios. Consists of the applications Tracking Hub and Studio Manager and is used in combination with Viz Engine and control applications such as Viz Trio, Viz Mosart and Viz Opus.
Tracking Hub
A control process (service) to receive, control and forward sensor input such as camera movements. A console program.
Studio Manager
A GUI program to setup and control Tracking Hub and the visual studio environment.
Rig
Refers to the physical objects such as camera rigs, pedestals and more.
Lattice
In a virtual studio environment, lattice is often used synonymous with RIG.
Cyc
Comes from the word Cyclorama. It was formerly used in theaters to encircle or partially enclose the stage from a background. In a Virtual Studio, the Cyc defines the green (or blue) area, where virtual objects can appear behind real objects.
CoCyc
The CoCyc is the mask (geometry), which will be used to hide real objects from the camera. The CoCyc is indirectly defined by the Cyc. Also known as the “trash matte”.
HUD
Heads Up Display.
Chroma Keyer
Chroma key compositing, or chroma keying, is a special effects / post-production technique for compositing (layering) two images or video streams together based on color hues (chroma range). The Viz Engine can generate key and fill and can, if required, also be used with an external Chroma keyer.
Synchronization
Using a reference signal to synchronize a video signal. Typical Blackburst, Tri-Level or using the Viz Engine digital input signal as sync.
