Viz Licensing Administrator Guide
Version 1.0 | Published November 27, 2017 ©
Supported Products
Viz Engine 3.9.1 or higher for cloud and virtualized deployments with no SDI output.
Graphic Hub 3.0.3 or higher.
Viz Engine requires a virtual GPU to run. Please refer to the Viz Engine Release Notes and Documentation about supported virtual GPUs.
Viz Engine will not start up if you are connected via Remote Desktop or TeamViewer, as they do not allow OpenGL output.
You might consider using a VNC client, for example TightVNC, as an administrative back-end tool.
