Viz Arc User Guide
Version 1.9 | Published October 31, 2023 ©
In-App Web API
Viz Arc provides a Web API that allows you to set DataMap variables, trigger specific actions or control the Playlist.
The samples below assume that Arc is running on localhost and the In-App Web API is configured to run on port 5004. The In-App Web API port can be configured in the General Settings, under the Communication section. Please note that this In-App Web API is only accessible when the Viz Arc application is running.
A Swagger webapp that describes every API can be found at http://localhost:5004/swagger/.
This section contains the following examples:
Information: The samples below use curl command line tools to demonstrate usage and python to beautify the returned JSON output. Note that these tools are not required for the Web API to function correctly.
Status
The Status endpoint allows you to get basic information of the running Viz Arc instance, such as version and uptime.
GET api/v1/status
curl -s -X GET http://localhost:5004/api/v1/Status | python -m json.tool
"version": "Viz Arc 1.8.0.2116",
"license": "CORE",
"uptime": "00:59:14.8406020"
ActionCanvas
The ActionCanvas endpoint allows you to retrieve all actions of a project, including information about their position, color, id etc.. An interactive demo page using this API can be found at http://localhost:5004/.
GET /api/v1/actioncanvas
This endpoints returns all actions of the currently loaded project. The property "actions" contains an array of all actions. The property tabs contains the information about the project tabs.
curl -s -X GET http://localhost:5004/api/v1/ActionCanvas | python -m json.tool
"tabs": [
"name": "show",
"isEditorOnly": false
"name": "Startlist",
"selectedTabIndex": 0,
"actions": [
"uuid": "a090e1c9-28ad-4c4f-976d-2727befe182d",
"name": "Title Day 1",
"type": "TEMPLATE",
"actionType": null,
"engineType": "VIZ",
"xSector": 1,
"ySector": 0,
"widthSector": 1,
"heightSector": 1,
"tab": 0,
"delay": 0,
"actionColor": "#65686B",
"textColor": "#DBDCDD"
"uuid": "95c0bc26-fb63-4ffe-becf-bd42db7ae5f8",
"type": "TEMPLATE",
"actionType": null,
"xSector": 0,
"ySector": 1,
"widthSector": 1,
"heightSector": 1,
"tab": 1,
"delay": 0,
"project": "Skating"
ActionExecuter
The ActionExecuter endpoint allows you to execute a specific action either by using its name or its ID.
GET /api/v1/actionexecuter/{id | name}
Executes the action specified by the id or name.
curl -s -X GET http://localhost:5004/api/v1/ActionExecuter/27cc7a3b-6f90-4d88-9101-a356a1668d83
200 OK
Using the ID variant is preferable as it uniquely identifies an action. Although the name might appear multiple times in your action collection, only the first action with the specified name is triggered.
GET /api/v1/actionexecuter/{id | name}/continue
Executes a "Continue" on a template action specified by the name.
curl -s -X GET http://localhost:5004/api/v1/ActionExecuter/27cc7a3b-6f90-4d88-9101-a356a1668d83/continue
200 OK
GET /api/v1/actionexecuter/{id | name}/out
Executes a "Out" on a template action specified by the name.
curl -s -X GET http://localhost:5004/api/v1/ActionExecuter/27cc7a3b-6f90-4d88-9101-a356a1668d83/out
200 OK
GET /api/v1/actionexecuter/{id | name}/update
Executes a "Update" on a template action specified by the name.
curl -s -X GET http://localhost:5004/api/v1/ActionExecuter/27cc7a3b-6f90-4d88-9101-a356a1668d83/update
200 OK
Arena
The Arena APIs allow you to control the Arena integration.
GET /api/v1/arena/detectArenaCalibration
Detects the calibration.
curl -s -X GET http://localhost:5004/api/v1/arena/detectArenaCalibration | python -m json.tool
200 OK
GET /api/v1/arena/clearArenaCalibration
Clears the current calibration.
curl -s -X GET http://localhost:5004/api/v1/arena/clearArenaCalibration | python -m json.tool
200 OK
GET /api/v1/arena/clearArenaKeyer
Clears the Viz Arena keyer
curl -s -X GET http://localhost:5004/api/v1/arena/clearArenaKeyer | python -m json.tool
200 OK
GET /api/v1/arena/setArenaCamera/{id}
Sets the active arena camera
curl -s -X GET http://localhost:5004/api/v1/arena/setArenaCamera/1 | python -m json.tool
200 OK
DataMap
You can set, read and delete DataMap variables through the Web API. An interactive web application can be found at http://localhost:5004/DataMap.
GET /api/v1/DataMap
Gets the list of all the key-value pairs.
curl -s -X GET http://localhost:5004/api/v1/DataMap | python -m json.tool
"key": "Hello",
"value": "World!"
"key": "WhiteListIPRanges",
"value": "0.0.0.0/0"
GET /api/v1/DataMap/{key}
Gets the key-value pair identified by the specified key.
curl -s -X GET http://localhost:5004/api/v1/DataMap/key | python -m json.tool
"key": "Hello",
"value": "World!"
POST /api/v1/DataMap
Adds a new key-value pair or an array of them to the DataMap. The payload must be sent as JSON body. If the key already exists the value will be updated.
curl -s -H 'Content-Type: application/json' -d "{ 'Key': 'Hello', 'Value': 'World!' }" -X POST http://localhost:5004/api/v1/DataMap
"Key": "key",
"Value": "hello"
DELETE /api/v1/DataMap/{key}
Delete a key/value pair by sending a DELETE message, for example to delete "key2" use:
curl -s -X DELETE http://localhost:5004/api/v1/DataMap/key2 | python -m json.tool
200 OK
Object Tracker
The Object Tracker APIs allow you to control the Object Tracker integration.
GET /api/v1/objectTracker/takeTracker
Takes all active trackers on-air.
curl -s -X GET http://localhost:5004/api/v1/objectTracker/takeTracker | python -m json.tool
200 OK
GET /api/v1/objectTracker/takeOutTracker
Takes all active trackers off-air.
curl -s -X GET http://localhost:5004/api/v1/objectTracker/takeOutTracker | python -m json.tool
200 OK
GET /api/v1/objectTracker/previewTracker
Previews all active trackers on the preview channel.
curl -s -X GET http://localhost:5004/api/v1/objectTracker/PreviewTracker | python -m json.tool
200 OK
GET /api/v1/objectTracker/previewOutTracker
Previews out all active trackers on the preview channel.
curl -s -X GET http://localhost:5004/api/v1/objectTracker/PreviewOutTracker | python -m json.tool
200 OK
GET /api/v1/objectTracker/stopTracker/{id}
Stops the tracker with index {id}, starting from index 1.
curl -s -X GET http://localhost:5004/api/v1/objectTracker/stopTracker/1 | python -m json.tool
200 OK
GET /api/v1/objectTracker/setActiveTracker/{id}
Sets the active tracker with index {id}, starting from index 1.
curl -s -X GET http://localhost:5004/api/v1/objectTracker/setActiveTracker/1 | python -m json.tool
200 OK
GET /api/v1/objectTracker/resetPointerOffset/{id}
Resets the pointer offset of the tracker with index {id}, starting from index 1.
curl -s -X GET http://localhost:5004/api/v1/objectTracker/resetPointerOffset/1 | python -m json.tool
200 OK
Playlist
You can read, trigger, preview and iterate through the playlist through the Web API. An interactive web application can be found at http://localhost:5004/PlayList.
GET /api/v1/playlist
Gets all the tabs:
curl -s -X GET http://localhost:5004/api/v1/PlayList | python -m json.tool
"duration": 10.0,
"index": 0,
"name": "Morning",
"rows": [
"actionUUID": "b78801bd-c802-42dd-ae11-9955c53dbfe3",
"duration": 5.0,
"id": "aaf0b451-1bb6-4bae-b11d-3b0c5f552e36",
"name": "AB"
"actionUUID": "6dd3107a-9487-4f32-92a0-b7eb83a1328f",
"duration": 5.0,
"id": "58b51c71-a904-4c95-b5d8-f42184af025e",
"name": "CD"
"duration": 15.0,
"index": 1,
"name": "Afternoon",
"rows": [
"actionUUID": "27cc7a3b-6f90-4d88-9101-a356a1668d83",
"duration": 5.0,
"id": "7f284bd1-a727-4e26-aea8-f417010c5386",
"name": "Opener"
"actionUUID": "955a622a-862b-4206-9658-a48b0c9f9a7e",
"duration": 5.0,
"id": "f43b4470-d08c-4261-8fb2-58ef97c4db28",
"name": "Closer"
"duration": 5.0,
"id": "483231c0-5484-478c-9bbc-74530dafa7cd",
"loop": false,
"name": "old",
"rows": [
"actionUUID": "ae7d2e75-552f-40e7-8c3d-7a8ef716809a",
"duration": 5.0,
"id": "c542f3d4-53d3-4aa1-82d1-8e75ae86342b",
"name": "Show Monitor"
The GET method returns all Playlist tabs and their respective rows and folders.
images/download/attachments/140811494/image2021-2-8_23-45-55.png
The screenshot above shows the query result for the "Morning" Playlist tab.
images/download/attachments/140811494/image2021-2-8_23-47-3.png
The screenshot above shows the query result for the "Afternoon" Playlist tab.
GET /api/v1/playlist/{index}
Gets the content of the playlist tab, by specifying its index:
curl -s -X GET http://localhost:5004/api/v1/PlayList/0 | python -m json.tool
"duration": 10.0,
"index": 0,
"name": "Morning",
"rows": [
"duration": 5.0,
"id": "17a6ee8d-8c82-4480-9bda-32e4b9447336",
"name": "AB"
"duration": 5.0,
"id": "4580c837-69a9-41b4-95dc-29b05f1ae0d4",
"name": "CD"
Starting from index 0 this call returns a single playlist tab only.
PlaylistExecuter
The PlaylistExecuter endpoint allow you to execute and preview individual playlist elements identified by their id.
GET api/v1/PlaylistExecuter/execute/{id}
Executes the playlist element identified by id.
curl -s -X GET http://localhost:5004/api/v1/PlaylistExecuter/execute/2628b63d-e947-4ee6-9dd2-5c90525e2cf5 | python -m json.tool
200 OK
GET api/v1/PlaylistExecuter/continue/{id}
Continues the playlist element identified by id.
curl -s -X GET http://localhost:5004/api/v1/PlaylistExecuter/continue/2628b63d-e947-4ee6-9dd2-5c90525e2cf5 | python -m json.tool
200 OK
GET api/v1/PlaylistExecuter/preview/{id}
Executes the playlist element identified by id on the preview channel.
curl -s -X GET http://localhost:5004/api/v1/PlaylistExecuter/preview/2628b63d-e947-4ee6-9dd2-5c90525e2cf5 | python -m json.tool
200 OK
GET api/v1/PlaylistExecuter/previewContinue/{id}
Continues the playlist element identified by id on the preview channel.
curl -s -X GET http://localhost:5004/api/v1/PlaylistExecuter/previewContinue/2628b63d-e947-4ee6-9dd2-5c90525e2cf5 | python -m json.tool
200 OK
GET api/v1/PlaylistExecuter/playPlaylistByName/{name}
Plays every item in the playlist identified by name.
curl -s -X GET http://localhost:5004/api/v1/PlaylistExecuter/playPlaylistByName/myPlaylist | python -m json.tool
200 OK
GET api/v1/PlaylistExecuter/playPlaylistByIndex/{id}
Plays every item in the playlist identified by Id.
curl -s -X GET http://localhost:5004/api/v1/PlaylistExecuter/playPlaylistByIndex/1 | python -m json.tool
200 OK
Playlist Controls on the Currently Selected Playlist
The following commands are invoked against the Playlist that is currently selected in Viz Arc:
GET api/v1/playlistexecuter/executeCurrent
Executes the currently selected playlist element.
curl -s -X GET http://localhost:5004/api/v1/playlistexecuter/executeCurrent
200 OK
GET api/v1/playlistexecuter/continueCurrent
Continues the currently selected playlist element.
curl -s -X GET http://localhost:5004/api/v1/playlistexecuter/continueCurrent | python -m json.tool
200 OK
GET api/v1/playlistexecuter/outCurrent
Takes out the currently selected playlist element (only for template actions).
curl -s -X GET http://localhost:5004/api/v1/playlistexecuter/outCurrent | python -m json.tool
200 OK
GET api/v1/playlistexecuter/previewCurrent
Executes the currently selected playlist element on the preview channel.
curl -s -X GET http://localhost:5004/api/v1/playlistexecuter/previewCurrent | python -m json.tool
200 OK
GET api/v1/playlistexecuter/previewContinueCurrent
Continues the currently selected playlist element on the preview channel.
curl -s -X GET http://localhost:5004/api/v1/playlistexecuter/previewContinueCurrent | python -m json.tool
200 OK
GET api/v1/playlistexecuter/previewOutCurrent
Takes out the currently selected playlist element on the preview channel (only for template actions).
curl -s -X GET http://localhost:5004/api/v1/playlistexecuter/previewOutCurrent | python -m json.tool
200 OK
GET api/v1/playlistexecuter/executeAndNext
Executes the currently selected playlist element and moves to the next playlist item.
curl -s -X GET http://localhost:5004/api/v1/playlistexecuter/executeAndNext | python -m json.tool
200 OK
GET api/v1/playlistexecuter/gotoFirst
Selects the first playlist item.
curl -s -X GET http://localhost:5004/api/v1/playlistexecuter/gotoFirst | python -m json.tool
200 OK
GET api/v1/playlistexecuter/playCurrentPlaylist
Plays every item in the currently selected playlist.
curl -s -X GET http://localhost:5004/api/v1/playlistexecuter/playCurrentPlaylist | python -m json.tool
200 OK
GET api/v1/playlistexecuter/stopCurrentPlaylist
Stops the execution of the currently selected playlist.
curl -s -X GET http://localhost:5004/api/v1/playlistexecuter/stopCurrentPlaylist | python -m json.tool
200 OK
Projects
The Projects endpoint allows you to get a list of all available projects and to load a project.
Information: Viz Arc can store and read projects from two different locations, Graphic Hub or the local file system. In order to distinguish the source of the project, the project's name is prefixed by the keywords "gh:" or "local:" (for example, "gh:sunday_elections" or "local:sunday_elections").
Also, the "location" property in the responses, indicates whether the project resides on Graphic Hub (value "1") or the file system (value "0").
GET api/v1/projects
Returns a list of all available Projects, first the projects located on the Graphic Hub, then the ones on the file system.
curl -s -X GET http://localhost:5004/api/v1/Projects | python -m json.tool
"name": "gh:Animations",
"lastModified": "2023-05-09T13:53:32.4633996+00:00",
"location": 1,
"profileIndex": 0,
"tabs": []
"name": "local:Skating",
"lastModified": "2023-05-11T07:53:51.80198+00:00",
"location": 0,
"profileIndex": 0,
"tabs": []
In the example above, two projects were found.
The name of the project is prefixed by the keywords "gh:" or "local:"; this prefix indicates wheter the project is stored in the Graphic Hub or on the file system.
GET api/v1/projects/load/{id}
Loads the project with the specified id in Viz Arc. If the id does not contain the location prefix, then Viz Arc tries to retrieve the project with a given name by looking in the Graphic Hub first, then the file system.
curl -s -X GET http://localhost:5004/api/v1/Projects/load/local:Skating | python -m json.tool
200 OK
GET api/v1/projects/current
Gets the name and location (Local or GraphicHub) of the currently loaded project.
curl -s -X GET http://localhost:5004/api/v1/projects/current | python -m json.tool
"location": 0,
"profileIndex": 2,
"tabs": [
"name": "show",
"index": 0,
"isEditorOnly": false,
"actions": [
"uuid": "ff1ae771-4c69-42e4-ba8a-ad98747a5477",
"name": "Logo",
"type": "Template",
"actionType": "TEMPLATE",
Profiles
The Profiles endpoint allows you to retrieve information about the available Profiles, Channels and Engines.
GET /api/v1/profiles
Returns the entire list of profiles available in Viz Arc.
curl -s -X GET http://localhost:5004/api/v1/profiles | python -m json.tool
"name": "Local",
"channels": [
"name": "Local",
"type": 1,
"engines": [
"name": "localhost"
"model": {
"engineConfigTuple": [
"item1": {
"name": "localhost",
"ipAddress": "127.0.0.1",
"port": 6100,
"launcherPort": 5644,
"webInterfacePort": 30010,
"webSocketPort": 30020,
GET api/v1/profiles/{id | name}
Returns the profile specified by the id or name.
curl -s -X GET http://localhost:5004/api/v1/profiles/0 | python -m json.tool
"name": "Local",
"channels": [
"name": "Local",
"type": 1,
"engines": [
"name": "localhost"
"model": {
"item1": {
"port": 6100,
GET api/v1/profiles/current
Returns the currently selected profile.
curl -s -X GET http://localhost:5004/api/v1/profiles/current | python -m json.tool
"name": "Local",
"channels": [
"name": "Local",
"type": 1,
"engines": [
"name": "localhost"
"model": {
"item1": {
"port": 6100,
POST api/v1/profiles
Sets the currently active profile.
curl -s -H 'Content-Type: application/json' -d "{ 'name': 'production' }" -X POST http://localhost:5004/api/v1/profiles
"name": "productionA"
curl -s -H 'Content-Type: application/json' -d "{ 'index': 0 }" -X POST http://localhost:5004/api/v1/profiles
"index": 0
Index starts at 0 for the first profile.
Web API Access Control
It is possible to inhibit calls to the PlayListExecuter and the ActionExecuter APIs with the IP whitelisting.
IP Whitelist
You can configure the IP addresses/ranges that are allowed to use the APIs. These have to be specified using a semi-colon (;) separated list of IP ranges (in CIDR notation). By default, the range is 0.0.0.0/0 which means all hosts can access the API.
The IP Whitelist can be configured in three different ways:
Web Application Whitelist configuration
If you want to allow only two machines with IP addresses (e.g. 192.168.1.100 and 192.168.1.142) you can specify them by reaching the page http://localhost:5004/DataMap and set the value of the WhiteListIPRanges key, as in the snapshot below.
images/download/attachments/140811494/datamap.png
Scripting Whitelist configuration
set Whitelist IP's through scripting
SetData("WhiteListIPRanges", "192.168.1.100;192.168.1.142")
Web Application Sample Usage
When Viz Arc starts up, it also launches an internal In-App Web Server which host a Web Application that makes use of some of the APIs described above.
Actions
Navigate to http://localhost:5004/ (the port can be configured in the General Settings, under the Communication section) to see the currently loaded project in Viz Arc. For example:
images/download/attachments/140811494/actions.png
You can click any of the tabs to see a simplified version of the actions. Click any action to execute it.
PlayList
Click the PlayList tab to see and trigger all available playlists and their elements:
images/download/attachments/140811494/Playlist.png
Datamap
Click the DataMap tab to view the current DataMap. From here you can add, delete or modify any DataMap variable.
Triggering a Viz Arc Action from the web browser
You can easily trigger a Viz Arc action for the currently loaded project using its GUID or just its name. First, get the GUID and name from the action:
images/download/attachments/140811494/image2021-3-2_17-12-37.png
The GUID is now copied to the clipboard from where you can easily paste it anywhere else (for example, to notepad):
images/download/attachments/140811494/image2021-3-2_17-14-43.png
Typing http://localhost:5004/api/v1/ActionExecuter/203e10df-8ba1-403c-a378-4d93186f4d06 or http://localhost:5004/api/v1/ActionExecuter/default triggers the action.
Information: Be aware that triggering only works when Viz Arc is running and when the project that contains the requested Action is open.
