Version 3.14 | Published November 11, 2019 ©
Matrox X.mio5 / DSX LE 5
The Matrox X.mio5 video board is the next generation IP card supporting SMPTE ST 2110-20/30/40 protocols. It is equipped with quad 25GbE SFPs delivering an effective, fully redundant bandwidth of 50GbE, capable of providing four UHD inputs and outputs. As with previous models, the DSX LE 5 provides the same capabilities without DVE functionality.
Important: The final models of X.mio5 won't have a genlock connector. Cards must be sync'd to PTP.
Key Features
Native SMPTE ST 2110 support with no CPU usage.
4x UHDp60/50 inputs and outputs over 25GbE.
ST 2110-21 packet pacing in hardware for narrow senders (Type N).
Wide asynchronous receivers (Type A).
32x HD inputs and outputs over 25GbE.
256 audio flows from one to 64 tracks.
Multi-channel HDR conversion.
On-board de-interlacing, scaling and compositing.
Integrated hardware PTP for ST 2059-2.
Built in NMOS IS-04 and IS-05 support.
Matrox X.mio5 Known Limitations
The current Beta version of the driver for X.mio5 still lacks some features, which will be part of the final version of the driver.
Only two of the four SFPs are available, limiting the effective bandwidth to 25GbE.
No SMPTE ST 2022-7 support on the inputs.
No ancillary data support on the inputs.
PTP only available on SFP A, no Best-Master-Clock-Algorithm support. Card must be sync'd to PTP.
Matrox X.mio5 Configuration
Please see section SMPTE 2110 Configuration for further details.
