Version 5.7 | Published June 12, 2024 ©
MOS Objects with Mosart Templates Grouped by Type
Variants for Mosart Templates of Same Type
A single MOS object will be created for Mosart templates of same type from the default template set. In this example
<mosExternalMetadata> node contains the list of variants for the Mosart templates, of same type.
<objID> of the MOS object is the template type, for example 0 for CAMERA or 1 for PACKAGE.
<objGroup> is the default template set name.
<type> node has the name set to the template type name (for example CAMERA, PACKAGE etc.), and templateset set to the name of the default template set.
mosObj
objID
>0</
objID
objSlug
>CAMERA</
objSlug
mosAbstract
>CAMERA</
mosAbstract
objGroup
>Talkshow</
objGroup
objType
>STILL</
objType
objTB
>50</
objTB
objRev
>1</
objRev
objDur
>0</
objDur
status
>NEW</
status
objAir
>NOT READY</
objAir
createdBy
createdBy
created
>2019-03-04T13:23:38,000Z</
created
changedBy
changedBy
changed
>2020-03-07T09:22:21,256Z</
changed
description
>CAMERA</
description
mosExternalMetadata
mosScope
>PLAYLIST</
mosScope
mosSchema
http://www.mosartmedialab.no/schema/mositem.dtd
mosSchema
mosPayload
mosarttemplate
type
name
"CAMERA"
templateset=”Talkshow”
category
variants
fieldtype
"LIST"
value
"1"
variant
name
"1"
transitions
value
"DEFAULT"
enable
"false"
transition
name
"DEFAULT"
field
name
value
fieldtype
"TEXT"
transition
transition
name
"MIX"
field
name
"transitionrate"
value
"0"
fieldtype
"NUMBER"
range
"0,999"
transition
transition
name
"WIPE"
field
name
"transitionrate"
value
fieldtype
"NUMBER"
range
"0,999"
transition
transition
name
"EFFECT"
field
name
"effectname"
value
fieldtype
"LIST"
keylist
"effects"
transition
transitions
fields
variant
variant
name
"2"
transitions
value
"DEFAULT"
enable
"false"
transition
name
"DEFAULT"
field
name
value
fieldtype
"TEXT"
transition
transition
name
"MIX"
field
name
"transitionrate"
value
"0"
fieldtype
"NUMBER"
range
"0,999"
transition
transition
name
"WIPE"
field
name
"transitionrate"
value
fieldtype
"NUMBER"
range
"0,999"
transition
transition
name
"EFFECT"
field
name
"effectname"
value
fieldtype
"LIST"
keylist
"effects"
transition
transitions
fields
variant
variants
keys
name
"mixerinputs"
k
k
k
>CAM1</
k
k
>CAM2</
k
k
>GRAPHIC1</
k
k
>GRAPHIC2</
k
k
>LIVE1</
k
k
>LIVE2</
k
k
>SKYPE1</
k
k
>SKYPE2</
k
k
>PLAYA</
k
k
>PLAYB</
k
k
>PLAYC</
k
k
>PLAYD</
k
k
>ME1</
k
k
>ME2</
k
k
>ME3</
k
keys
keys
name
"effects"
k
>1</
k
k
>2</
k
k
>3</
k
k
>4</
k
k
>5</
k
k
>6</
k
k
>7</
k
k
>8</
k
k
>9</
k
k
>10</
k
k
>11</
k
k
>12</
k
k
>13</
k
k
>14</
k
k
>45</
k
k
>47</
k
keys
keys
name
"routersources"
k
>SAT_10</
k
k
>DEP_01_A</
k
keys
keys
name
"routerdestinations"
k
>M_VISU_2</
k
k
>M_ROBO_2</
k
k
>TESTLOW</
k
k
>TESTHIGH</
k
keys
type
mosarttemplate
mosPayload
mosExternalMetadata
mosObj
Variants for Mosart Templates of Same Type and SendAllTemplateSets set to True
A single MOS object will be created for Mosart templates of the same type for each template set. In this example:
<mosExternalMetadata> node contains the list of variants for the Mosart templates of the same type.
For example, if there are 3 template sets and 10 template types having 2 variants each, then there are 30 MOS objects created, each having 2 variants. -
<objID> is the “TemplateSet-TemplateType”.
For example in the ’FuncSpec’ template set, FuncSpec-0 for CAMERA or FuncSpec-1 for PACKAGE. -
<objSlug> is the template type name.
For example, CAMERA or PACKAGE. -
<objGroup> is the template set name.
<type> node has the name of the template type name (for example CAMERA, PACKAGE etc.), and templateset set to the name of the template set.
In the example below there are there are 2 template sets:
- FuncSpec having 3 Camera templates and
- Demo having 2 Camera templates.
<mosObj>
<objID>FUNCSPEC-
0
</objID>
<objSlug>CAMERA</objSlug>
<mosAbstract>CAMERA</mosAbstract>
<objGroup>Funcspec</objGroup>
<objType>STILL</objType>
<objTB>
50
</objTB>
<objRev>
1
</objRev>
<objDur>
0
</objDur>
<status>NEW</status>
<objAir>NOT READY</objAir>
<createdBy>
</createdBy>
<created>
2016
04
-01T11:
42
09
,000Z</created>
<changedBy>
</changedBy>
<changed>
2017
09
-22T12:
05
20
,070Z</changed>
<description>CAMERA</description>
<mosScope>PLAYLIST</mosScope>
<mosSchema>http:
//www.mosartmedialab.no/schema/mositem.dtd</mosSchema>
<mosPayload>
<mosarttemplate>
<type name=
"CAMERA"
templateset=
"Funcspec"
category=
<variants fieldtype=
"LIST"
value=
"LIVE"
<variant name=
"LIVE"
<transitions value=
"DEFAULT"
enable=
"false"
<transition name=
"DEFAULT"
<field name=
value=
fieldtype=
"TEXT"
</transition>
<transition name=
"MIX"
<field name=
"transitionrate"
value=
"0"
fieldtype=
"NUMBER"
range=
"0,999"
</transition>
<transition name=
"WIPE"
<field name=
"transitionrate"
value=
fieldtype=
"NUMBER"
range=
"0,999"
</transition>
<transition name=
"EFFECT"
<field name=
"effectname"
value=
fieldtype=
"LIST"
keylist=
"effects"
</transition>
</transitions>
<fields>
<field name=
"xpoint1"
value=
"CAM1"
default
"CAM1"
fieldtype=
"LIST"
keylist=
"mixerinputs"
</fields>
</variant>
<variant name=
"21"
<transitions value=
"DEFAULT"
enable=
"false"
<transition name=
"DEFAULT"
<field name=
value=
fieldtype=
"TEXT"
</transition>
<transition name=
"MIX"
<field name=
"transitionrate"
value=
"2"
fieldtype=
"NUMBER"
range=
"0,999"
</transition>
<transition name=
"WIPE"
<field name=
"transitionrate"
value=
fieldtype=
"NUMBER"
range=
"0,999"
</transition>
<transition name=
"EFFECT"
<field name=
"effectname"
value=
fieldtype=
"LIST"
keylist=
"effects"
</transition>
</transitions>
<fields />
</variant>
<variant name=
"20"
<transitions value=
"DEFAULT"
enable=
"false"
<transition name=
"DEFAULT"
<field name=
value=
fieldtype=
"TEXT"
</transition>
<transition name=
"MIX"
<field name=
"transitionrate"
value=
"2"
fieldtype=
"NUMBER"
range=
"0,999"
</transition>
<transition name=
"WIPE"
<field name=
"transitionrate"
value=
fieldtype=
"NUMBER"
range=
"0,999"
</transition>
<transition name=
"EFFECT"
<field name=
"effectname"
value=
fieldtype=
"LIST"
keylist=
"effects"
</transition>
</transitions>
<fields />
</variant>
</variants>
<keys name=
"mixerinputs"
<k>
</k>
<k>CAM1</k>
<k>CAM2</k>
<k>LIVE1</k>
<k>VIZ</k>
<k>IN11_HD1</k>
<k>IN12_HD2</k>
<k>VIZ2</k>
<k>ME1</k>
<k>ME2</k>
<k>LIVE2</k>
<k>DUMMY</k>
<k>DDR1</k>
<k>DDR2</k>
</keys>
<keys name=
"effects"
<k>
1
</k>
<k>
2
</k>
<k>
3
</k>
<k>
4
</k>
<k>
5
</k>
<k>
6
</k>
<k>
7
</k>
<k>
8
</k>
<k>
9
</k>
</keys>
<keys name=
"routersources"
<k>R CAM
1
</k>
</keys>
<keys name=
<k>OPUS
1
</k>
</keys>
</type>
</mosarttemplate>
</mosPayload>
</mosExternalMetadata>
</mosObj>
<mosObj>
<objID>DEMO-
0
</objID>
<objGroup>DEMO</objGroup>
<objTB>
50
</objTB>
<objRev>
1
</objRev>
<objDur>
0
</objDur>
<createdBy>
</createdBy>
<created>
2014
11
-11T12:
55
05
,000Z</created>
<changedBy>
</changedBy>
<changed>
2016
05
-04T11:
01
27
,903Z</changed>
<mosSchema>http:
<mosPayload>
<mosarttemplate>
<type name=
"CAMERA"
templateset=
"DEMO"
category=
"LIST"
value=
"1"
<variant name=
"1"
<transitions value=
"DEFAULT"
enable=
"false"
<transition name=
"DEFAULT"
<field name=
value=
fieldtype=
"TEXT"
</transition>
<transition name=
"MIX"
<field name=
"transitionrate"
value=
"0"
fieldtype=
"NUMBER"
range=
"0,999"
</transition>
<transition name=
"WIPE"
<field name=
"transitionrate"
value=
"10"
fieldtype=
"NUMBER"
range=
"0,999"
</transition>
<transition name=
"EFFECT"
<field name=
"effectname"
value=
"0"
fieldtype=
"LIST"
keylist=
"effects"
</transition>
</transitions>
<fields />
</variant>
<variant name=
"2"
<transitions value=
"DEFAULT"
enable=
"false"
<transition name=
"DEFAULT"
<field name=
value=
fieldtype=
"TEXT"
</transition>
<transition name=
"MIX"
<field name=
"transitionrate"
value=
"50"
fieldtype=
"NUMBER"
range=
"0,999"
</transition>
<transition name=
"WIPE"
<field name=
"transitionrate"
value=
"50"
fieldtype=
"NUMBER"
range=
"0,999"
</transition>
<transition name=
"EFFECT"
<field name=
"effectname"
value=
"0"
fieldtype=
"LIST"
keylist=
"effects"
</transition>
</transitions>
<fields />
</variant>
</variants>
<keys name=
"mixerinputs"
<k>
</k>
<k>CAM1</k>
<k>CAM2</k>
<k>LIVE1</k>
<k>VIZ</k>
<k>IN11_HD1</k>
<k>IN12_HD2</k>
<k>VIZ2</k>
<k>ME1</k>
<k>ME2</k>
<k>LIVE2</k>
<k>DUMMY</k>
<k>DDR1</k>
<k>DDR2</k>
</keys>
<keys name=
"effects"
<k>
1
</k>
<k>
2
</k>
<k>
3
</k>
<k>
4
</k>
<k>
5
</k>
<k>
6
</k>
<k>
7
</k>
<k>
8
</k>
<k>
9
</k>
</keys>
<keys name=
"routersources"
<k>R CAM
1
</k>
</keys>
<keys name=
<k>OPUS
1
</k>
</keys>
</type>
</mosarttemplate>
</mosPayload>
</mosObj>
