Version 5.7 | Published June 12, 2024 ©
ta_templatetypealias
The ta_templatetypealias table contains custom user aliases for the Mosart template types. These aliases are used by Mosart ManusAdministrator to translate user aliases to the corresponding Mosart template types.
Name |
Type |
Allow Null |
Description |
ta_recno |
integer |
No |
Primary key. |
ta_name |
varchar(32) |
No |
The template type alias name. Should be unique, as this is presented to the users. |
ta_description |
varchar(128) |
Yes |
Optional template type alias description. |
ta_tt_recno |
integer |
No |
Foreign key referencing the corresponding Mosart template type in the tt_templatetype table. |
ta_default |
smallint |
Yes |
A value of 1 is used for the ‘default’ alias among those belonging to the same template type. For each template type, exactly one alias belonging to that type should have ta_default = 1. |
Information: The ta_templatetypealias table is the only table that is maintained and used by Mosart ManusAdministrator containing the NRCS template type aliases.
