Version 5.7 | Published July 22, 2024 ©
ScreenLL Configuration File
The ScreenLL configuration file is named ClipServerScreenLL.xml.
<?xml version=
"1.0"
encoding=
"utf-8"
<MediaServerConfig xmlns:xsi=
"http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd=
"http://www.w3.org/2001/XMLSchema"
<Properties>
<!-- Language code to look
for
to decide clip availability -->
<item name=
"AvailabilityLanguageCode"
value=
"OPN"
<!-- First Incue Time code that indicates invalidated clip -->
<item name=
"InvalidatedFirstIncueTime"
value=
</Properties>
</MediaServerConfig>
Properties
AvailabilityLanguageCode: Specifies which language code must be present in order for a clip to be marked as available. The language code is a three letter text string, which relates to a list of language codes found in the file PoliSTLServerLangs.lst, which must be present on the ScreenLL subtitle file server.
InvalidatedFirstIncueTime: Specifies the First Incue Time value that will indicate that a subtitle clip has been invalidated (is not available even if it matches the AvailabilityLanguageCode).
Other configuration items are customer-specific or for Vizrt internal use only.
