![](assets/images/logos/VizTrioLogo.png)
Viz Trio User Guide
Version 4.2 | Published April 02, 2024 ©
Import and Export Settings
To view the Import/Export configuration settings, click Import/Export Settings in the Viz Trio Configuration.
Import and Export Configuration Settings
This function lets you import and export the configuration settings from and to an XML-file, letting you apply customized settings to Viz Trio clients without manually configuring the settings each time.
Export settings and profile configurations to an XML file. The following settings cannot be exported:
Keyboard Shortcuts and Macros settings (can be exported separately).
Word replace settings under the Text Editor settings (can be exported separately).
Viz Pilot Database settings.
All Connectivity settings.
Import Viz Trio settings and profile configurations from an XML file.
Note: Import overwrites existing settings and profiles. Viz Trio must be restarted for the new configurations to take effect.
