Viz Trio User Guide
Version 4.2 | Published April 02, 2024 ©
Overview of Commands
The commands are grouped as follows:
Channelcontrol
Command Name and Arguments
Description
add_channel(restString channelName)
Adds a new channel to the active profile. The named channel must not exist.
get_active_profile
Returns the name of the active profile.
get_preview_channel
Gets the name of the currently configured Viz preview channel. Returns an empty string if no Viz preview channel is defined.
get_program_channel
Gets the name of the currently configured Viz program channel. Returns an empty string if no Viz program channel is defined.
get_video_preview_channel
Gets the name of the currently configured video preview channel. Returns an empty string if no video preview channel is defined.
get_video_program_channel(restString channelName) @TODO check args
Gets the name of the currently configured video program channel. Returns an empty string if no video program channel is defined.
list_profiles
Returns a list of existing profiles, separated by line breaks.
list_video_channels
Returns all video channels of the current profile as comma separated list.
list_viz_channels
Returns all Viz channels of the current profile as comma separated list.
remove_channel(restString channelName)
Removes the channel with the given name from the active profile. The channel name must be valid.
set_active_profile(restString profileName)
Change the active channel profile.
set_asset_storage (string host-name, restString storage-name)
Sets the publishing point to be used for all handlers in the active profile. The storage name is the user visible title for the asset storage.
set_channel_hosts(string channelname, restString hostlist)
Changes the list of Viz hosts for a channel. The referenced channel must exist. The list of hosts can be space/comma/semi-colon separated.
set_preview_channel(restString channelName)
Changes the Viz preview channel. The channel name must be valid. If empty the Viz preview channel is undefined.
set_program_channel(restString channelName)
Changes the Viz program channel. The channel name must be valid. If empty the Viz program channel is undefined.
set_video_channel_hosts(string channelname, restString hostlist)
Changes the list of video hosts for a channel. The referenced channel must exist. The list of hosts can be space/comma/semi-colon separated.
set_video_preview_channel(restString channelName)
Changes the video preview channel. The channel name must be valid. If empty the video preview channel is undefined.
set_video_program_channel(restString channelName)
Changes the video program channel. The channel name must be valid. If empty the video program channel is undefined.
wait_vizcmd_to_channel(string channel, restString cmd)
Sends a Viz Engine command to a named channel and waits for the returned answer.
Gui
Description
add_view (title min max elementTypeList)
Creates a new view. If called without any parameters, the PageView dialog is shown. Min and max may optionally be specified to filter elements with numeric names. Elements with non-numeric names are always included. elementTypeList is an optional space-separated list of types of elements to include in the view. Possible values are: pages stills videos empty_groups. If none are specified, they are all included.Example 1: gui:add_view "The Title" 2000 3500 pages stills. This shows pages and stills in the range between 2000 and 3500. Videos are not shown and empty groups are hidden.Example 2: gui:add_view title2 videos. This shows all videos, nothing else.
artist_mode
Enter design mode (Viz Artist).
browse_image
Browse local file system for images.
change_path
Shows the directory selector.
clear_page_field
Clears the content of the page edit’s text field.
change_path
Opens the browser for either shows or external playlists.
copy_selected_pages_to_number(restString destnumber)
Copy the selected pages to number or show a dialog if no number is supplied.
copy_selected_pages_with_offset(restString destnumber)
Copy the selected pages with an offset or show a dialog if no number is supplied.
design_mode
Enter Viz Trio design mode.
edit_begin_time
Shows the in place editor for the selected page.
edit_end_time
edit_group_name
edit_page_description
edit_page_program_channel
edit_scroll
Show the scroll editor.
edit_template(restString templateName)
Edit the specified template in a dialog. This only works for templates in concept-enabled shows.
error_message (restString message)
Display an error message in the status bar. The message is also logged.
find
Shows the find dialog.
focus_active_view
Set the keyboard focus to the active page view.
focus_next_view
Activate the next page view.
focus_prev_focused_view
Focus the previous focused view.
focus_prev_view
Activate the previous page view.
get_callup_code
Gets the value of the callup code window.
get_selected_pages
Retrieves the currently selected pages as a space separated list.
goto_config
Opens Viz Trio’s Configuration Window.
hide_timecode_monitor
Hides the TimeCode monitor. See also show_timecode_monitor.
hit_test(x:integer, y:integer)
Test if a tab field exists on the X,Y coordinate.
load_image_from_viz
Show the viz image browser for the current tab field.
log_message(restString message)
Add a message to the logfile.
move_selected_pages_to_number(restString destnumber)
Move the selected pages to number or show a dialog if no number is supplied.
move_selected_pages_with_offset(restString destnumber)
Move the selected pages with an offset or show a dialog if no number is supplied.
open_playlists
Shows the directory selector for the external playlists. Typically MOS playlists.
open_shows
Opens the show browser.
open_effect_dialog
This command opens the effect dialog. It does not open if the current page isn't set.
play_video
Play video in video preview.
playout_mode
Enter playout mode.
post_render
Opens the post render editor.
prepare_snapshot
Open the prepare snapshot editor.
print_selected_pages
Print the selected pages in the active view.
read_page_following_last_taken
Read the page succeeding the page that was last taken.
reimport_selected_pages
Reimport the selected pages in the active view.
search_video (restString search_text (optional video id))
Search for video.
select_last_taken_page
Select the page that was last taken.
select_nextpage
Select the next page in the active view.
select_prevpage
Select the previous page in the active view.
set_autopreview(boolean autopreview)
Sets the auto-preview state (single-click read) for page views.
set_bounding_box(visible:boolean)
Toggles the bounding boxes for the elements in the preview (same as the BB button).
set_column_visible(string columnname, boolean active)
Sets the visiblity of the column. Applies to all pageviews.
set_focus_to_editor
Sets focus to the currently active tab field editor.
set_font (restString fontname)
Set the default GUI font.
set_interactive_mode(boolean active)
Sets interactive mode which controls whether to show dialogs to the user or not.
set_run_script_button_enabled(boolean IsEnabled)
Sets the run script button to enabled/disabled.
set_safearea(visible:boolean)
Toggle safe area.
set_silent_mode(boolean active)
Sets silent mode which controls whether to show dialogs to the user or not.
set_statusbar_color(int R, int G, int B)
Sets the color of the statusbar based on the RBG values given.
set_titlearea(visible:boolean)
Toggles the title area in the preview window.
set_mam_service_document_uri [uri [username password]]
The parameters are optional. If no parameters are provided the command should disable the Viz One configuration. Otherwise it enables the configuration if necessary and sets the new URI and possibly also the credentials if those parameters are provided.
set_media_search_credentials username password
This command changes the credentials used for when doing media searches on Viz One.
show_viz_preview
Show Viz preview.
show_custom_prop_column(boolean value)
Shows or hides custom property column in tab field list.
show_custom_property_editor_for_current_tabfield
Opens the inplace editor for the custom property of the current tab-field if the custom column in the tab-field tree is visible.
show_export_dialog
Show the export show dialog.
show_export_selected_page_dialog(string showPath)
Display the selected pages export show dialog. showPath parameter is optional. It is almost same as the Export Show feature but it exports only selected pages & all it's associated items.
show_external_cursor(boolean value)
Show or hide the external cursor in the page view.
show_feed_streamer_moderation
Opens the feed streamer moderation tool if Viz SocialTV is installed.
show_import_dialog
Show the import show dialog.
import_viz_archive
Initiate the viz archive import process. This triggers the file open dialog to select the viz engine archive(.via) file from disk.
show_pageeditor
Shows the page editor.
show_pages_in_rundown(boolean doShow)
Shows or hides pages in the rundown for the current show.
show_pageview
Show the page view.
show_playlist (string refPath, boolean requestMos, restString description)
Shows the playlist with the specified path or name. Can choose to request a MOS playlist. Description is optional and defaults to the playlist name.
show_scripteditor
Shows the script editor.
show_scroll_template_creator
Shows the scroll template creator view.
show_settings
Open the show properties view.
show_search_media
Shows the search media view.
show_search_video
Shows the search video view.
show_shortcut_list
Show the view of local shortcuts and macros.
show_showscript_editor
Shows the show script editor.
show_status_icons(boolean value)
Shows or hides status cells in the callup grid.
show_templates_in_rundown(boolean doShow)
Shows or hides templates in the rundown for the current show.
Shows the TimeCode Monitor. See also hide_timecode_monitor.
show_triocommands
Toggles the Viz Trio Commands window.
status_message(restString message)
Display a text message in the status bar. The message is also logged.
take_callup
Take the current callup number directly, without a read.
take_snapshot(string path, string handlerName)
Takes snapshot from the specified handler in RGB format.
take_snapshot_rgba(string path, string handlerName)
Takes snapshot from the specified handler in RGBA format.
toggle_design_mode
Toggle between Viz Trio design and playout mode.
toggle_error_message_window
Toggle the visibility of the error message window.
toggle_hide_nameless_groups(visible:boolean)
Toggle hide/show groups with no name.
Macro
Description
export_macros_to_xml(string filename)
Exports the macro commands to an XML file.
export_macros_shortcuts_to_xml (string filename)
Exports shortcuts information of global macro commands to an XML file.
import_macros_shortcuts_from_xml (string filename)
Imports shortcuts information of global macro commands from an XML file.
Main
Description
apropos(search:string)
Search command names and descriptions for a string.
call_macro(restString name)
Call (invoke) a named macro.
define_local_macro(string name, restString commands)
Define a named, local macro.
define_local_script(string name, restString commands)
Define a named, local script.
define_macro(string name, restString commands)
Define a named, global macro.
define_script(string name, restString commands)
Define a named, global script.
delete_global_macro(name:string)
Delete a global macro.
delete_local_macro(name:string)
Delete a local macro.
get_global_macros
List the names of global macros (separated by new lines).
get_local_macros
List the names of local macros (separated by new lines).
get_shows
Get the names of all the shows in the client.
get_version
Get a version string.
help(command:string)
Shows help for the specified command, or lists commands.
macro(macro)
Runs the specified macro command.
Page
Description
arm(pageName:string, channelName: string)
Arms the specified page on the specified channel. If channelName is empty, the default channel is used.
arm_current(channelName:string)
Arms the currently read page on its specified program channel. If channelName is empty, the default channel is used.
arm_selected
Arm the selected page.
cancel_refresh_linked_data(page name (optional))
Cancel refreshing of linked data, started with the 'page:refresh_linked_data_async' command.
change_channel("string FromChannel, string ToChannel, boolean All)
Switch from "FromChannel" to "ToChannel". "All" changes all elements using "FromChannel".
change_description(string pageNr, restString desc)
Sets the page description.
change_template(string templateName)
Changes the template of the selected pages. Empty parameter("") take the number in the callup field and use that as the template ID.
change_template_for_pages(string templateName, restString pages)
Changes the template of the given pages.
change_thumbnail_uri (string pageName, restString newThumbnailURI)
Changes the thumbnail URI for the referenced page. The URI and the page name must be valid.
change_variable(string variable, restString value)
Change the variant for the currently edited page.
continue(pageName, channelName)
Only applicable to videos. Continues a video on a named channel. If channel is not mentioned it plays the video on its designated channel. If the clip name is not mentioned the current clip is continued. Such as, page:continue 1000 A continues the clip “1000” on channel “A” while just page:continue 1000 would continue clip “1000” on its designated channel.
cue(pageName, channelName)
Cues a page on a named channel. If channel is not mentioned it cues the page on its designated channel. If the page name is omitted the current page is cued. Such as, page:cue 1000 A cue the page “1000” on channel “A” while just page:cue 1000 would cue page “1000” on its designated channel.
cue_append(pageName, channelName)
Only applicable to videos. The command interrupts the current playing clip and immediately starts playing the selected video on the named channel. Such as, page:cue_append 1000 A cue the video “1000” on channel “A” while just page:cue_append 1000 would cue video “1000” on its designated channel.
cut(pageNumber, channelName)
Cuts a page on the named channel. If channel is omitted it cuts the page on its designated channel. Such as, page:cut 1000 A cuts the page “1000” on channel “A” while just page:cut 1000 would cut page “1000” on its designated channel.
delete_page
Delete selected page(s) in active view.
delete_pagerange(int start, int end)
Deletes the page inside from the begin range to (including) the end range parameter.
direct_continue
Continue selected page in active view.
direct_cut
Cut selected page in active view.
direct_take
Take selected page in active view.
direct_takeout
Take out selected page in active view.
direct_cue
Cue the selected video on the video program channel
direct_cue_append
Cue append the selected video on the video program channel
direct_pause
Pause the currently playing video on the video program channel
export_property(string key, string filename)
Export a property value to file (UTF-8 encoded).
fire(channelName:string, action:string, clearAfterFire:boolean)
Fire a channel with the given action (take, continue, out, and so on). If clearAfterFire is true, the armed element on the channel is un-armed after fire.
fire_all(action:string, clearAfterFire:boolean)
Fire all armed channels with the given action (take, continue, out, and so on). If clearAfterFire is true, the armed elements on the channels are un-armed after fire.
get_current_propertykey
Get the current property-key.
get_current_tabfield_name
Get the name of the current tab field.
get_layers(string page)
Get the layer name(s) the combination or transition logic page is based on, hence, this command is not valid for pages based on standalone scenes (returns an empty string).
get_program_pagechannel(restString pageid)
Gets the program channel for the page.
get_property(string name)
Get the value of the specified tabfield property.
get_tabfield_names ( optional: pageName)
Retrieves the tab-field names of the given page or the current page if no page is specified. The returned list is space separated.
get_tabfield_count
Gets the number of tabfield on the current page.
get_template_description(string page)
Gets the template description for the page specified.
get_viz_layer(restString page)
Gets the viz layer for a page. If no page name is supplied, current page is used. Only valid for scene-based pages.
getpagedescription
Get the description of the current page.
getpagename
Get the name of the current page.
get_property_keys (pageName optional)
Retrieves the property keys of the given page or the current page if no page is specified. The returned list is space separated.
get_variable(string variable)
Retrieves the value of a variable of the currently read page.
getpagetemplate
Get the template of the current page.
import_property(string key, string filename)
Import a property value from file (UTF-8 encoded).
load_page_data(filename:string (optional))
Load page data from XML.
pause(pageName, channelName)
Only applicable to videos. Pauses a named video on a named channel. If channel is not mentioned it pauses the element on its designated channel. If the video name is not mentioned then current video is paused. Such as, page:pause 1000 A pause the video “1000” on channel “A” while just page:pause 1000 would pause video “1000” on its designated channel.
prepare(pageName, channelName)
Prepares a named element on a named channel. If channel is not mentioned it prepares the element on its designated channel. If the element name is not mentioned the current element is prepared. Such as, page:prepare 1000 A prepare the page “1000” on channel “A” while just page:prepare 1000 would prepare page “1000” on its designated channel.
prepare_current_on_channel <channel-name>
Prepares the currently read element to a channel other than the specified channel for that element.
print
Print the current page. Use settings printer/left_margin, printer/right_margin, printer/top_margin, printer/bottom_margin to control the size, where the value is the percent of the page width/height.
read(pageNr:integer)
Reads the specified page number.
read_parentpage
Read the parent of a sub page.
read_rootpage
Read the root page in a page hierarchy.
read_subpage(string string)
Read a sub page of another page, for instance a scroll element. Argument format: "tabfield key/pagenumber", eg. "1/1003".
read_template(string templateid)
Reads a template if concepts and variants are enabled. If not, read a normal template.
read_template_with_context(string template, string contextPairs)
Read a master template with context variables that can override the show properties. The context is given a whitespace-separated list of keys and values.
readnext
Read next element in active view.
readprevious
Read previous element in active view.
redo
Redo edit in current page history.
Refresh linked data if the page has any tabfields that are linked to data from an external source.
refresh_linked_data_async(page name (optional))
Start refreshing linked data if the page has any tabfields that are linked to data from an external source. The refresh can be cancelled with the 'page:cancel_refresh_linked_data' command.
run_command_with_variables_on_channel(string command, string channel, restString variables)
Run a command (for example a take) on a page with variables to a specific channel.
save
Saves current page.
save_page_data(filename:string (optional), version:string (optional, defaults to 2.6))
Save page data as XML in specified version (2.5 or 2.6).
save_scene
Save current page as a new Viz scene.
save_thumbnail
Save a thumbnail for the currently read Viz Trio page, based on the content of the renderer. The thumbnail is stored in the Media Sequencer and shown in the page list.
saveas(integer)
Goes in saveas mode or saves page to page given as argument. Triggers the save as action for a template or page, saving it with the page number as parameter. If no parameter is given, the callup code is set to the next available page number. However, the page isn't saved.
set_effect(restString effect)
Sets the transition effect to be used between (scene-based) pages. Empty string specifies hard cuts (default).
set_effect_on_selected(string effect)
Sets the transition effect to be used between (scene-based) pages on the currently selected one. Empty string specifies hard cuts (default).
set_expert_mode_enabled(boolean enabled)
Enable or disable "expert mode" for the current page. This enables all tab field properties to be accessed instead of a filtered subset. Restarting Viz Trio resets the expert mode.
set_pagestatus(status: string)
Set the status of the selected pages. Valid arguments: FINISHED/UNFINISHED/NONE.
set_pagestatus_one(pagenr: integer, status: string)
Set the status of page. Valid status arguments: FINISHED/UNFINISHED/NONE.
set_pagetime(string pageid, string type, string value)
Sets the begin/end time for the page specified.
set_program_pagechannel(string pageid, restString channelname)
Sets the program channel for the page.
set_property(string name, restString value)
Set the value of a named tab field property.
setpagetemplate(string templateName)
Change the template of the current page.
store
Save the page with the name given in the read page edit field (the left one).
tab
Tab to the next tab field.
tab_backwards
Tab to the previous tab field.
tabto(tabfieldnr:integer)
Go to a specific tab-field number.
tabtotabfield(tabfieldname:string)
take (pageName, channelName)
Plays the named element on its designated channel. If channel is not mentioned it plays the element on its designated channel. If the page name is omitted then the current page is played. Such as, page:take 1000 A takes the page “1000” on channel “A” while just page:take 1000 takes the page “1000” on its designated channel.
take_exchange
Take current page and read the last page that was taken.
take_with_variables(restString variables)
Take a page with variables.
take_with_variables_on_channel
Take a page with variables to a specific channel.
takenext
Take current page and read next page in active view.
takeout(pageName, channelName)
Takes out the named element from the named channel. If channel is not mentioned it takes out the element from its designated channel. If the element name is not mentioned then the current element takes out from the designated channel. Such as, page:takeout 1000 A takes out the page “1000” on channel “A” while just page:take 1000 would take out page “1000” from its designated channel.
unarm(channelName:string)
Unarms the specified channel.
unarm_current
Unarms the currently read page on the channel it is armed.
unarm_all
Un-arms all armed pages.
undo
Undo edit in current page history.
update
Update the program renderer (do a take without animating it in).
update_preview
Update the external preview renderer with the contents of the local preview.
Playlist
Description
add_page(string pagename, restString duration)
Add a page to the end of the playlist. The duration argument is optional. If not given, the page duration is used.
create_playlist(string name)
Adds a new empty global playlist and returns the path to the new playlist. The name of the playlist is optional. If not specified, a dialog pops up to ask for it. The new playlist shows up in the "playlists" in the "Change Show" dialog.
close (restString: id)
Closes a specified playlist. The id parameter is either the path or the unique identifier of the playlist to close. If omitted the current playlist is closed.
copy_to_show (restString start_num)
Copy the elements in the playlist to the current show
clear (restString id)
Clears the specified playlist. The id can be the playlist path or its identifier. If omitted the current playlist gets cleared.
direct_take_out_selected
Take out the currently selected playlist element.
direct_take_selected
Take the selected playlist item onair without previewing it.
get_concept
Retrieves the concept of a playlist.
get_current
Retrieves the path of the playlist which is the current one. May return an empty string.
get_playlists
Retrieves a list of all open playlists in the current show as space separated list of playlist references which can be used to refer to playlists in other commands like playlist:set_current.
go_to_next_story
Select the next story (group) in the active playlist.
go_to_previous_story
Select the previous story (group) in the active playlist.
goto_manual_graphics_mode(restString enable)
Enable/disable manual playout of graphic elements. Use "true" or "" for manual and "false" for automatic mode.
initialize_playlist
Initialize the playlist (load graphics) on the external output channels.
jump_to_ncs_cursor
Jump to the element that the NCS-cursor (newsroom control system) is pointing to.
pause_carousel
Pause the carousel.
read_next_item
Read the next playlist item.
read_prev_item
Read the previous playlist item.
read_selected
Read the currently selected playlist element.
reload_thumbnails (restString: template_names)
Reload the thumbnails for the given templates on all open playlists. Reloads all thumbnails if no templates are given.
run_selected_with_custom_action (string Action)
This macro command is generic and can append any Media Sequencer command as a parameter for playing out selected graphics and/or video clip elements in any playlist.Example: playlist:run_selected_with_custom_action "prepare"{{playlist:run_selected_with_custom_action "take"}}Note that if you have a version of the Media Sequencer that is newer than the version released with your version of Viz Trio, you can still use new commands supported by the Media Sequencer by using this macro command.
select_first
Select the first element in the playlist.
select_next
Select the next element in the active playlist.
select_next_by_description(restString phrase)
Selects the next element in the active playlist which has the given phrase in its description.
set_channel_on_selected (restString channelName)
Set the channel for all selected items in the current playlist
set_current (string: id)
Defines the specified playlist as the current one for operations like add_item. The id can be the playlist path or its identifier.
select_previous
Select the previous element in the active playlist.
set_attribute_on_selected(string attribute, restString value)
Sets an attribute on all the selected items in a playlist.
set_concept(restString value)
Set the concept for a playlist.
set_filter (restString: filerName)
Set the filter of the currently active playlist. The filter must already exist. Calling with no filter name resets the filter of the playlist.
set_looping(restString looping TRUE or FALSE)
Set to true if the carousel shall be looping.
start_carousel (playlist name or id (optional, defaults to active playlist))
Run the elements in the playlist as a carousel.
stop_carousel (playlist name or id (optional, defaults to active playlist))
Stop a playlist running as a carousel.
Proxy
Description
enable_viz_proxy(boolean enable)
Enables/disables Viz Trio acting as a Viz Proxy on the port configured.
set_proxy_port(int port)
Set the port that Viz Trio should listen on.
set_viz_host(string host)
Set the host where the proxy can locate Viz.
set_viz_port(int port)
Set the port the proxy should use to access Viz.
Rundown
Description
go_to_next_story
Sets focus on the next story/group in the active rundown.
Sets focus on the previous story/group in the active rundown.
reload_template_images(restString templates)
Reloads the thumbnails for all listed scene paths. If the scene paths are not given all thumbnails are reloaded.
Script
Description
eval(restString scriptExpression)
Evaluate the VBScript expression given as a parameter, and return the value converted to a string.
execute_script
Tries to run the OnUserClick event on the current template script. Doesn't report any errors e.g. if the event is not handled in the template script.
get_showscript_name
Gets the name of the current show script. Specify full name, does not add .vbs to the script name
import_script(string scriptName, restString scriptFilename)
Imports the script into the current show.
run_macro_script(restString scriptCode)
Run the VBScript script code given as a parameter. The snippet can contain multiple lines of code. The macro returns an empty string or an error message.
run_script(string scriptFunction, restString argumentList)
Run the specified script function. The argument list is a list of strings separated by commas or white space. Arguments that can contain commas or white space must be enclosed by double quotes.
run_showscript(string scriptFunction, restString argumentList)
Run the script associated with the current show. The argument list is a list of strings separated by commas or white space. Arguments that can contain commas or white space must be enclosed by double quotes.
Scroll2
Description
add_easepoint(string pagename)
Add an easepoint to the current scroll.
clear_elements
Clear scroll elements (remove all).
copy_element(int sourceIndex, int targetIndex)
Add a copy of scroll element at sourceIndex to targetIndex.
create_scroll_template(string sceneName, string templateDescription, float width, float height, boolean showBounds)
Create a new scroll template with the given parameters.
edit_easepoint(string subpage, string easepoint)
Edit an easepoint in the current scroll.
insert_objects(int index, restString objects)
Insert SCENE or GEOM objects from viz into the current scroll.
insert_pages(int index, restString pages)
Insert pages from current show into current scroll at index.
insert_range(int index, string range)
Insert an inclusive numerical range of pages (e.g 1000-2000) from the current show, or a single page.
move_element(int sourceIndex, int targetIndex)
Move scroll element from sourceIndex to targetIndex.
next_easepoint
Go to next ease point editor.
next_element_data
Go to next element data (extra spacing) editor.
preview_continue
Continue the current scroll in preview.
preview_start
Start the current scroll in preview.
preview_stop
Stop the current scroll in preview.
previous_easepoint
Go to previous ease point editor.
previous_element_data
Go to previous element data (extra spacing) editor.
program_continue
Continue the current scroll on the program channel (must be taken on-air first).
program_start
Start the current scroll on the program channel (must be taken on-air first).
program_stop
Stop the current scroll on the program channel (must be taken on-air first).
reload_all_page_data
Reload all scroll page data by copying from original pages.
reload_page_data(int index)
Reload scroll page data at index by copying from original page.
reload_template_graphics
Reload all scroll elements (reload geometry objects created during import of templates).
reload_templates
Reload all scroll elements by merging with the current show templates.
remove_easepoint(string subpage, string easepoint)
Remove a named easepoint in the current scroll.
remove_element(int index)
Remove scroll element at index.
rename_easepoint(string subpage, string oldName, string newName)
Rename an easepoint in the current scroll.
set_focus(int index)
Focus on scroll element.
Settings
Description
apply_gateway_settings
Applies all MOS gateway settings which have been set up previously.
get_setting(string path)
Gets a Viz setting.
get_global_setting (string: path)
Get a global setting.
get_vcp_database_connection_string
Get VCP database connection string
get_vcp_database_schema
Get VCP database schema
export_to_file (boolean: include_settings, boolean: include_profiles, restString filename)
Export settings to a file. If filename is empty, a file dialog is shown.
enable_gateway (boolean: flag)
Enables or disables the MOS gateway according to the given flag. After running this command settings:apply_gateway_settings have to be run in order to put the setting operative.
import_from_file (restString: filename)
Export settings to a file using old format for import on Viz Trio 2.6 and earlier. If filename is empty, a file dialog is shown.
import_from_file (restString filename)
Import settings from a file. If filename is empty, a file dialog is shown.
start_gateway
Starts the MOS gateway handler of the Viz Media Sequencer Engine.
restart_gateway
Restarts the MOS gateway handler of the Viz Media Sequencer Engine.
set_gateway_host (string hostname [<port_nummer>])
Changes the MOS gateway host name and port. <host-name> must be a valid host name or IP address where the gateway is running. <port-number> must be a valid port number. It is optional and defaults to 10640. After running this command settings:apply_gateway_settings have to be run in order to put the setting operative.
set_gateway_ncs_id (string: id)
Changes the gateway NCS ID. After running this command settings:apply_gateway_settings have to be run in order to put the setting operative.
set_gateway_mos_id (string: id)
Changes the gateway MOS ID. After running this command settings:apply_gateway_settings have to be run in order to put the setting operative.
set_gateway_messages_per_second (int: seconds)
Changes the number of messages per second to process by the MOS gateway. A zero value disables this setting. After running this command settings:apply_gateway_settings have to be run in order to put the setting operative.
set_vcp_database (string: connection_string, string: Schema)
Set VCP database connection setting
set_global_setting
Sets a global Viz setting (e.g. settings:set_global_setting encoding ISO-8859-1).
set_setting(string path, restString value)
Set a show setting.
set_send_item_stat (boolean: flag)
Enables or disables the item stat sending of the MOS gateway according to the given flag. After running this command settings:apply_gateway_settings have to be run in order to put the setting operative.
stop_gateway
Stops the MOS gateway handler of the Viz Media Sequencer Engine.
Show
Description
append_pages_from_xml(boolean showDialogs, string filename)
Loads pages from XML and replaces any pages that are overwritten.
copy_pages (restString: pageList)
Copies the given page(s) to the clipboard
copy_pages_to_number(int destination, restString CommaSeperatedList)
Copy the pages to a destination number.
copy_pages_with_offset(int offset, int CommaSeperatedList)
create_combo_template (string: name, string: pagellist)
Create a combo master template.
create_group(string groupname)
Create a page group in the current show, before the focused node.
create_playlist(restString name)
Adds a new playlist to the show and returns the path to the new playlist. If name is omitted, a dialog pops up asking for a name.
create_show(restString showPath)
Create a new show. The show path may specify a show within a show folder.
cut_pages (page list)
Cuts the given page(s) to the clipboard.
delete_all_pages
Deletes all the pages in the page view.
delete_templates(restString templateList)
Delete the given templates from the current show. Does nothing if the show does not have concepts and variants enabled.
enable_context
Enable concept/variant for the current show.
export_setting(string name, restString value)
Configure an export setting, use this before export_show.
export_show(filename:string)
Export a show (Viz Trio archive).
get_associated_files
Get the list of associated files for the show
get_background_scenes
Get a space-separated list of background scenes in the show.
get_concept
Get the show-concept.
get_context_variable(string variable)
Get the show-context-variable.
get_custom_colors
Get the custom colors for the current show.
get_default_viz_path
Get the default viz scene path for the current show.
get_group_pages
Returns a list of pages in the specified group.
get_groups
Returns a list of groups in the current show.
get_library_path
get_page_xml(restString page_path)
Get the xml for the specified page. The path is given as showpath/<page-id> (e.g. get_page_xml myshow/1000). For "untitled show" use empty showpath (e.g. get_page_xml /1002). Note that show names are case sensitive.
get_pages
Returns a list of pages in the current show.
get_preview_background_image
Get the Preview background image for the current show.
get_scenes_for_pages(restString pagelist)
Get the list of scenes for the given pages.
Get a show setting.
get_settings
Get all settings.
get_show_description
Get the description of the current show.
get_show_name
Get the name of the current show.
get_templates
Returns a list of templates in the current show.
get_variable(string propname)
Get the value of a show variable.
get_variant
Get the show-variant.
goto_viz_dir(path:string)
Change to a show with the same name as a viz directory, creating it if necessary.
import(scenes:string)
Shows the Import Scenes pane or imports specified scene(s).
import_and_initialize(scenes:string)
Import scenes to templates, then reload on external renderers.
import_no_gui(restString sceneNames)
Imports the scenes given as parameter without showing/closing the import GUI.
import_pages_from_xml(string filename, int offset, boolean interactive, boolean pageNames)
Import the named pages from an XML file. An offset different from zero causes pages with numerical names to be offset by this number, unless they are templates. Pages are overwritten automatically if interactive is false.
import_recursively(string path)
Import all the scenes recursively from this folder.
import_setting(string name, restString value)
Configure an import setting, use this before import_show.
import_show(filename:string)
Import a show (Viz Trio archive).
load_armed
Load all armed elements on their channels.
load_locally
Loads all scenes referenced by pages in the current show on the local viz preview.
load_show
Load show (scenes, textures, fonts) on external output channels. Replaces the old initialize command.
load_show_on_renderers(string ProgramChannelName, restString PreviewChannelName)
Load current show on the specified channels. First argument is treated as a program channel, second as preview.
move_pages_to_group(string group, restString pages)
Move pages into the specified group. If the group name is empty, move to top level.
move_pages_to_number(int destination, restString CommaSeperatedList)
Move the pages to destination number
move_pages_with_offset(int destination, int CommaSeperatedList)
Move the pages with an offset.
paste_pages
Pastes the given page(s) from the clipboard to the current show.
page_exists (restString page)
Checks if a page with the specified name exists in the current show. Returns "true" or "false".
reimport_templates (string: templateList)
Reimport the given templates
reload_current_show
Reloads the current show
reload_on_renderers (string: template_l
Reload (re-initialize) graphics for the specified master templates or scene info on program and preview channels.
load_on_renderers(restString pages)
Load (initialize) graphics for the specified pages on program and preview channels.
rename_page(string old_name, restString new_name)
Rename a page name in the opened show
save_pages(string FileName, restString CommaSeperatedList)
Saves the pages given as parameter to XML.
save_pages_to_xml(string filename)
Saves pages to XML.
save_selected_pages(restString fileName)
Saves the selected pages to XML.
set_associated_files(restString filelist)
Set the associated files for the show. ("file1" "file2" "file3").
set_concept(restString concept)
Set the show-concept to a new value.
set_concept_for_all (restString concept)
Set the given concept to the show and to all playlists, or no concept if the parameter is omitted.
set_context_variable(string variable, restString value)
Set the show-variant to a new value.
set_custom_colors(restString colors)
Set the custom colors for the current show.
set_default_scene_effect (restString: effect)
Sets the default transition effect to be used between (scene-based) pages. Empty string specifies hard cuts (default).
set_default_video_effect (restString: effect)
Sets the default transition effect to be used between videos and stillstore images. Empty string specifies hard cuts (default).
set_default_viz_path(path:string)
Set the default viz scene path for the current show.
set_dir(restString path)
Changes the show directory to the path specified.
set_external_cursor(restString pagename)
Set the external cursor to page with page name or to current page if page name is empty.
set_filter
Set the filter of the page list or the currently active page view. The filter must already exist. Calling with no filter name resets the filter of the page view.
set_library_path(restString path)
Set the design-library path.
set_preview_background_image(path:string)
Set the preview background image for the current show.
Set a show setting.
set_show_description(description:string)
Set the description of the current show.
set_show_name(name:string)
Set the name of the current show.
set_variable(string propname, restString value)
Set the value of a show variable. The value is stored on the Media Sequencer.
set_variant(restString variant)
show_export_dialog_for_path(restString showpath)
Exports the show.
Sock
Description
connect_socket
Explicitly connect (open) the socket, if not already connected.
disconnect_socket
Disconnect (close) the socket, if connected.
send_socket_data(restString text)
Send UTF-8 encoded text over the socket. If it is a server socket, send to all clients.
set_com_baud(int comBaudRate)
Set baud rate to use for the serial port.
set_com_number(int comPortNumber)
Set COM port number to use for the serial port.
set_socket_autoconnect(boolean autoconnect)
If auto-connect is true, a client socket is connected the first time data is sent, or a server socket is opened automatically.
set_socket_data_separator(string separator)
Set the separator for the OnSocketDataReceived callback.
set_socket_encoding(string encoding)
Set text encoding for socket to either UTF-8 or ISO-8859-1.
set_socket_host(string hostname)
Set the socket hostname. Does nothing if the socket type is server.
set_socket_port(int port)
Set the socket port number.
set_socket_type(string type)
Set the socket type to client or server.
socket_is_connected
Returns true if the socket is connected, false otherwise.
Tabfield
Description
active(active:string)
Toggle active flag of current tab field or set its value (0 or 1).
browse_file
Change to the browse file editor of the current tabfield or set the full path to a file.
clock
Change to clock editor of current tab field or set its value (string).
downcase_tabfield
Convert current tab field to lower case, if it contains text.
edit_property(string propertyName)
Changes editor to the specified property i.e 1.image.
geom(vizPath:string)
Change to geometry editor of current tab field or set its value (GEOM*path).
get_custom_property(string tabfieldName)
Gets the custom property of the tab field. "" gets it for the current tab field.
get_tabfield_property(tabfieldnr:integer,property:string)
Gets a property value for a given tab field.
image(vizPath:string)
Change to image editor of current tab field or set its value (IMAGE*path or filename).
image_position
Change to image position editor of current tab field or set its value (two floats).
image_scaling
Change to image scaling editor of current tab field or set its value (two floats).
import_value_from_file(restString filename)
Load a tab field value from a text file (UTF-8 encoded).
kerning(value:float)
Change to kerning editor of current tab field or set its value (float).
material(vizPath:string)
Change to material editor of current tab field or set its value (MATERIAL*path).
next_property
Select the next property of the current tab field, or the first if the last one is currently selected.
position(value:float)
Change to position editor of current tab field or set its value (floats).
previous_property
Select the previous property of the current tab field, or the last if the first one is currently selected.
rotation(value:float)
Change to rotation editor of current tab field or set its value (floats).
scaling(value:float)
Change to scaling editor of current tab field or set its value (float).
set_custom_property(string tabfieldName, string value)
Sets the custom property of the tab field. "" as tab-field name uses the current tab field.
set_tabfield_property(prop:string, value:string)
Set a property value.
set_value(value:string)
Sets the value of the current tab-field property.
text(value:string)
Change to text editor of current tab field or set its value (unicode string).
toggle_current_custom_property(string value1, string value2)
Toggle the custom property of the current tab field between the two given values.
upcase_tabfield
Convert current tab field to upper case, if it contains text.
value
Change to default editor.
Table
Description
clear_sorting(string table key)
Clear the sorted state of a table property.
delete_rows(string table key, string row index list)
Delete a number of rows from a table property.
get_row_num (string: table_key)
Get the number of rows of a table property.
insert_rows_with_xml (string: table_key, int: row_index, restString: XML_data_to_insert)
Insert several rows with their data into a table property.
get_cell_value(string table key, string column key, int row num)
Get a cell value of a table property.
list_columns (string: table_key)
Returns the column IDs of a table property as space separated list.
insert_rows(string table key, int row index, int number of rows to insert)
Insert a number of rows into a table property.
move_current_row_down
Move the selected row in the current table editor one step downwards.
move_current_row_up
Move the selected row in the current table editor one step upwards.
move_row(string table key, int row index to move, int target row index)
Move a row downwards behind the target row or upwards before the target row.
set_cell_value(string table key, string column key, int row num, restString new value)
Set a cell value of a table property.
sort_column(<table key> <column key> [ascending or descending] (optional, default: ascending))
Sort a table ascending or descending after a column.
Text
Description
incr_alpha(string key, string selectionStart, string selectionEnd, float alpha)
Increment or decrement the transparency of selected text.
incr_kerning(string key, string selectionStart, string selectionEnd, float kerning)
Increment or decrement the kerning of selected text.
incr_position(string key, string selectionStart, string selectionEnd, float posX, float posY, float posZ)
Increment or decrement the position of selected text.
incr_rotation(string key, string selectionStart, string selectionEnd, float rotX, float rotY, float rotZ)
Increment or decrement the rotation of selected text.
incr_scale(string key, string selectionStart, string selectionEnd, float scaleX, float scaleY, float scaleZ)
Increment or decrement the scaling of selected text.
revert(string key)
Revert current text to saved value.
set_alpha_mode
Set text manipulation mode to Alpha.
set_color(string key, string selectionStart, string selectionEnd, string color)
Change the color of selected text.
set_color_mode
Set text manipulation mode to Color.
set_justification(string key, string justification)
Set the text justification (LEFT, CENTER, RIGHT).
set_kerning_mode
Set text manipulation mode to Kerning.
set_position_mode
set_rotate_xy_mode
Set text manipulation mode to Rotate x and y.
set_rotate_z_mode
Set text manipulation mode to Rotate z.
set_scale_mode
Set text manipulation mode to Scale.
show_replace_list
Shows the pre-configured character palette for the character to the left of the cursor.
Viz Trio
Description
activate_current_playlist
Activate current playlist
assign_script(string page, boolean fileScript, restString scriptunit)
Assign or change the script for the template of the specified page. Note: This affects all pages using this template. Example:
trio:assign_script 1001 True page1001
cleanup
Performs a clean-up of the current show with all playlists on external renderers by clearing Viz layers and freeing memory.
check_channels_status
Check connection status of program and preview channels in profile. Both for Viz Engine and video channels. Returns "true" if all are good, "false" otherwise.
cleanup_all_channels
Cleans up all channels in the current profile by clearing Viz layers and freeing memory. Does not clear the channel for transition logic pages.
cleanup_channel(restString channelname)
Cleans up the specified channel by clearing Viz layers and freeing memory. Note: The trio:clear_channel command duplicated the trio:cleanup_channel command and is therefore as of version 2.10 deprecated.
cleanup_renderers
Cleans up the renderers of the current playlist (frees graphics and clears output) on the utilized external output channels.
clear_preview
Cleans up Viz preview channel by clearing Viz layers and freeing memory.
clear_program
Cleans up Viz program channel by clearing Viz layers and freeing memory.
continue_last_taken_page
Continue the page that was last taken.
create_snapshot_page
Takes a snapshot and creates a page with that snapshot.
deactivate_current_playlist
Deactivate current playlist
exchange
Exchange the content of the program and external preview.
exit
Close Viz Trio.
freeze_program_clock(string string)
Freeze a clock on the program machine.
get_global_variable(string propname)
Get the value of a global variable.
get_next_savenumber
Get the number that is proposed on the next save as or with a create_snapshot_page.
help
Opens Viz Trio user guide. The help file is also opened by clicking the Help button in the user interface (next to Config), or by pressing the F1 key unless it has been assigned to another action (e.g. macro). See also General settings.
initialize
Initializes the current show (both page list and all playlists) on external renderers.
initialize_show_or_playlist
Initialize current show or playlist on external renderers.
invoke_with_current_page(string commandName)
Invoke the given command with the name of the current page as a parameter (useful for macro shortcuts).
invoke_with_current_scene(string commandName)
Invoke the given command with the name of the current scene as a parameter (useful for macro shortcuts).
offair
Set client in off-air mode.
onair
Set client in on-air mode.
open_printsettings_dialog(restString pages)
Open the printer-settings dialog.
print_and_save_snapshots(restString pages)
Print the pages. Use settings printer/left_margin, printer/right_margin, printer/top_margin, printer/bottom_margin to control the size, where the value is the percent of the page width/height.
print_snapshots(restString pages)
Print the pages. Use settings printer/left_margin, printer/right_margin, printer/top_margin, printer/bottom_margin to control the size, where the value is the percent of the page width/height. With no argument, the content of the preview is printed.
process_ii_string(restString value)
Sends a string to the intelligent interface handler on the Media Sequencer and lets it process it.
rename_show_folder (string: old_name, restString: new_name)
Rename a folder.
rename_show (string: old_name, string: new_name)
Rename a show.
restart_local_viz
Restarts the local Viz preview channel.
restart_local_viz_program
Restarts the local Viz program channel. Only available when local program channel has been started.
send_local_vizcmd(command:string)
Send a command or a list of commands separated by newlines to the local viz preview. Returns a list of return values from viz. Newlines within a single command must be escaped (\n).
send_preview_vizcmd(command:string)
Send a Viz command to the preview renderer.
send_preview_vizcmd_noerror(restString command)
Send a Viz command to the preview renderer if possible, otherwise do nothing (no error message).
send_vizcmd(command:string)
Send a Viz command to the program renderer.
send_vizcmd_to_channel(string channelName, restString command)
Send a Viz command to a specified channel.
set_global_variable(string propname, restString value)
Set the value of a global property. The value is stored on the Media Sequencer.
set_mcu_folder(string string)
Sets the folder of the MCU/AVS plug-in.
set_vizconnection_timeout(int timeout)
Set the Viz connection timeout.
set_next_savenumber (int: name)
Set the number that is proposed on the next save as or with a create_snapshot_page
show_trio_settings_dialog
Show dialog containing a tree view of Viz Trio settings.
show_settings_dialog (restString: category)
sleep(int millisec)
Sleeps a page a certain amount of milliseconds.For example:TrioCmd("page:take 1000") TrioCmd("trio:sleep 10000") TrioCmd("page:take 1001") TrioCmd("trio:sleep 10000") TrioCmd("page:takeout")
swap_channels
Swap the program and preview channels.
synchronize_clocks
Synchronize the clocks to the clocks on the program renderer.
takeout_last_taken_page
unfreeze_program_clock(string string)
Util
Description
get_node_text(string string)
Gets the node text of a Media Sequencer node.
list_archive_files(filename:string)
Returns a list of files in a Viz Trio archive (also works for other tar files).
list_archive_pages(filename:string)
Returns a list of pages in a Viz Trio archive (creates a list of all_pages.xml within the Viz Trio archive).
list_archive_parameters(restString filename)
Returns a list of parameters of a Viz Trio archive.
list_xml_pages(restString filename)
Returns a list of pages in an XML file.
run_mse_entry(string path)
Runs the node at the specified path. No context is given.
set_node_text(string path, restString value)
Sets the node text of a Media Sequencer node.
Viz
Description
cleanup_locally
Cleanup (unload) all viz resources locally. If a scene is active in the local renderer, it is not cleaned up.
continue
Continue the animation in viz preview (if stopped).
import_image_from_file(string filename, restString pool folder)
Import the given image file into the given viz image pool folder.
play
Start (play) the animation in viz preview.
load_data_locally (boolean: paths)
Load viz resources locally. The space-separated list of paths must include the pool prefix and full path, e.g. SCENE*folder/name
reload_data_locally(boolean paths)
Reload viz resources locally. The space-separated list of paths must include the pool prefix and full path, e.g. SCENE*folder/name.
set_bounding_box(boolean visible)
Toggle bounding box visibility.
set_key_alpha
Viz Artist setting.
set_key_preview
Viz Artist setting.
set_rgb
Viz Artist setting.
set_safearea(boolean visible)
Toggle safe area visibility.
set_stage_pos(restString pos)
Set the current stage position.
set_titlearea(boolean visible)
Toggle title area visibility.
stop
Stop the animation in viz preview.
set_format(string format)
Switch preview to the given adaptive scene design format.
set_next_format
Switches preview to the next available adaptive scene format.
set_previous_format
Switches preview to the previous available adaptive scene format.
vtwtemplate
Description
get_template
Gets the VTW template for the current show.
import_template(string ScriptName, restString FileName)
Imports a template from file to the current show. Overwrites any template with the same name.
reimport_active_template
Reimports the active VTW template for the current show.
run_vtw_function(string functionName, restString argumentList)
Deprecated, use vtwtemplate: invoke_function instead.
Runs a script function in the active VTW template. The argument list is a list of strings separated by commas or white space. Arguments that can contain commas or white space must be enclosed by double quotes.
invoke_function(string functionName, restString argumentList)
Execute a script function in the active VTW template. The argument list is a list of strings separated by commas or white space. Arguments that can contain commas or white space must be enclosed by double quotes.
run_vtw_script(string FunctionName, restString Data)
Runs a script function in the active VTW template. Only a single parameter is supported by the Data parameter, so use vtwtemplate:invoke_function instead if possible.
set_template(restString templateName)
Sets the VTW template for the current show.
