Version 1.4 | Published October 30, 2020 ©
Important Checklist Before Installation
The items listed below must be checked before an installation can be done on site. Before an installation can be started make sure:
  • Camera adjustments/shifts should always be set by camera personnel before any lens calibration is done. After any adjustments/shifts are set, the camera cannot be adjusted without being reconfigured.
  • Cables: Who is in charge of the cabling before doing an installation?
  • Tracking: What are the tracking system protocols?
  • Transfer of tracking data: How is tracking data transferred and what kind of cables are used?
  • Synchronization sources: What type of synchronization sources used?
    • Blackburst
    • Tri-level
    • Digital input 1&2 using SDI in
  • Location of the Viz Engines: Do you have physical access to the machines?
  • Coordinate system: What are the coordinate systems for the tracking system(s) used?
  • Make sure that there are no firewalls enabled.
System Requirements
This section details the system requirements.
Synchronization
The Tracking Hub needs some sort of synchronization method on the machine it is installed. This can be:
  • A running Viz Engine installation, or
  • An installed Plura synchronization card.
    Note: If sync sources is not found, Tracking Hub can still be used in free running mode. Free running is not intended and should not be used for production. It can, however, be used to experiment with tracking on a laptop. For use in production, either Viz Engine or Plura synchronization is necessary.
    Note: 32-bit Operating Systems are no longer supported. For versions 1.2 and later, Tracking Hub and Studio Manager are available in 64-bit only.
Minimum Hardware Configuration
  • Minimum 8 GB Ram
  • Dual-Core Intel CPU
  • Windows 10 64-bit or Windows 7 (64-bit)
  • Minimum 10 GB of free disk space
  • OpenGL Hardware-accelerated Graphics Card
Minimum Hardware Configuration for use with Post and Replay
  • Minimum 16 GB Ram
  • Minimum 30 GB of free disk space
Recommended Hardware and Software Configuration
  • 32 GB Ram
  • Quad-Core Intel CPU
  • Windows 10 64-bit
  • 30 GB of free disk space
  • Nvidia P2000 Graphics Card
Supported Hardware and Software
  • Windows 10 (64-bit)
  • Viz Engine 3.9.0 (either 32-bit or 64-bit) or later
  • Plura PCL-PCI and PCL-PCIe (L, LV, 3G) timecode reader cards (Driver 5.34)
    Important: The PCL-PCI L card can only read timecodes and can NOT be used for synchronization.
  • Studio Manager requires .NET framework 4.5.1 or higher.
