![](assets/images/logos/Gateway.png)
Gateway Administrator Guide
Version 5.2 | Published March 01, 2019 ©
MOS Protocol Support
Gateway supports the following MOS profiles:
Profile |
Definition |
Supported |
Vizrt comment |
0 |
Basic Communications |
yes |
1 |
Basic Object Based Workflow |
yes |
2 |
Basic Running Order/Content List Workflow |
yes |
3 |
Advanced Object Based Workflow |
partly |
only mosItemReplace is used |
4 |
Advanced RO/Content List Workflow |
yes |
5 |
Item Control |
partly |
only roCtrl is supported |
6 |
MOS Redirection |
yes |
Gateway supports these MOS protocol versions:
Protocol version |
Supported |
2.6 |
yes |
2.8.0 |
yes |
For more information about the MOS protocol, see mosprotocol.com.
