![](assets/images/logos/Gateway.png)
Gateway Administrator Guide
Version 5.2 | Published March 01, 2019 ©
Minimum Hardware Requirements
The following hardware components are required for the Gateway and Oracle Database Client. The requirements are separate, and only depicts the actual requirements needed to run each of the software installations.
Gateway
There are no specific hardware requirements for Gateway. The hardware required and network interface is depending on how many Newsroom Systems and clients that use the gateway. However, it is strongly recommended that Gateway is installed on its own computer or server. Sharing space with other resource-intensive systems, for example a database, is not recommended.
Currently (for Oracle 11g) the requirements are listed as:
Oracle hardware requirements (11g)
Requirement |
Minimum Value |
Physical memory (RAM) |
1 GB minimum |
Virtual memory |
Double the amount of RAM |
Disk space |
Total: 5.22 GB |
Processor |
AMD64 or Intel EM64T |
Video adapter |
256 colors |
Screen Resolution |
1024 X 768 minimum |
IMPORTANT!
The values above are correct as of October 2017 and should be read as minimum required, please refer to the official Oracle Documentation at docs.oracle.com for updated information.
Note:
The Oracle database client is not necessary if you are connecting to Oracle via the Pilot Data Server.
