Text FX Slide
The Text FX Slide plug-in allows you to create a sliding animation of the characters on the X, Y and Z-axis.
Text FX Slide Properties
X, Y and Z Distance: Defines direction and distance of moved text.
Show Direction: Enables and disables view of movement vector.
Note: The direction is not shown in On Air mode.
