Advanced Counter
The Advanced Counter plug-in allows you to easily create an animated counting sequence. It shows values with decimals and it has the possibility to create a user defined format mask. Furthermore it can have prefixed values.
Advanced Counter Properties
Use Integers: Enables the use of integers only.
Value (Dec.), Value (Int.): Sets the current value of the counter. Animate this value to create the counting sequence.
Leading blanks: you can here choose what the counter does with leading blanks. They can either be Cut away or put in as Blank, asterisk, hash, dot or zeros.
Force prefix: Enables both positive and negative values to have a prefix, not only negative values as is the default (+/-).
Delete unnecessary commas: Removes superfluous commas when a specified format mask has more commas than the number needs. If for instance the mask $###,###,###,###.## is defined, and the number 4120.37 is entered, it will be output as $,,4,120.37. If by enabling this option, the number will get a correct format: $4,120.37.
Decimal separator: Switches the decimal separator between point and comma.
Format mask: Allows you to define a format mask. Each hash symbolizes an item of the total number. To alter, add or remove hashes. You can also add constant values, for example DM, NOK etc.
Initialize: Starts the counter.
To Create an Advanced Counter
Add a group container to the scene tree.
Add a font and material to the group container.
Add the Advanced Counter plug-in to the group container.
Open the Advanced Counter editor and animate the parameters.
