Line Chart
This plug-in draws a line chart, filled with data out of a Shared Memory Map. You can use delimited strings or arrays for data transfer via Scene-, Global- or Distributed-Shared Memory.
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> VisualDataTools
Line Chart Properties
Shared Mem.: Changes between Scene, Global and Distributed Shared Memory. Use Inactive memory to not forward any values via Shared Memory
Specify X Values: Enables DataX input
DataX: Shared Mem. key name for X values. DataX is the default input parameter for X values
Key DataX: Shared Mem. key name for X values
DataY: Shared Mem. key name for Y values. DataY is the default input parameter for Y values
Key DataY: Shared Mem. key name for Y values
Transfer Mode: Sets string- or array-based data transfer
Data Delim.: Defines the value separator sign(s)
Number Format: Defines if Viz should get the decimal point separator from the System Locale or Custom settings. If Custom is enabled,
Decimal Symbol: Defines which symbol is used as decimal point when Custom Number Format is set.
Note: If the Line Stack plug-in is used, the following Line Chart properties need to be defined in the Line Stack plug-in.
DataX, -Y Fit: Enables data normalization
DataX, -Y Scale: Scales input by the selected factor
DataX, -Y Offset: Adds an offset to the incoming data
DataX, -Y Auto Scale: Enables automatic data normalization
DataX, -Y Fit Size: Total: Scales the whole chart to the defined borders. Current: Scales the current chart segment to the set borders
DataX, -Y Detect Limits: Detects minimum and maximum of all values and scales them to adjusted Start and Stop. This option is used to upscale the interesting part of a chart - especially if there are only little changes between the data values
DataX, -Y Threshold: Adds a definable offset to the detected limit
DataX, -Y Start: Lower Auto Scale edge
DataX, -Y Stop: Upper Auto Scale edge
Data Animation: Set the animation type to be created when data change is detected:
Disable: No animation
Timer: Create data transition animation (from an old set of data to a new set) within the specified time set in Duration sec.. Also select an Animation Mode
Director: Create data transition animation with the Stage Director, that controls the Animation Progress parameter from 0.0% (old data) to 100.0% (new data). Also select an Animation Mode
Animation Mode:
Concurrent: All nodes change concurrently
Left to Right: Transition from left to right
Right to Left: Transition from right to left
Balance Speed: Set to On, when Animation Mode is set to Left to Right or Right to Left, and the position of transformed data will be related to node values as well
Example:Balance Speed: If the values of four nodes change from 0,0,0,0 to 1,9,90,900 in Left to Right mode at 50% of the transformation. Balance Speed Off: Only the first two nodes will be transformed to new values. Balance Speed On: The first three nodes are already transformed to new values, and the last node also transformed to 44% of the new values, because the data change from 0 (0+0+0+0) to 1000 (1+9+90+900), at 50% of transformation (in this case the values is changed for 500 of 1000), the first 3 nodes are already finished and the last node is changed to 400
Durationsec.: Set the duration of the animation in seconds for Timer mode
Horizontal Alignment: Sets horizontal orientation to left, center or right.
Line Type:
Normal: direct connections between entered values.
Spline: interpolates extra values to chamfer the graph.
Constrained Spline: Same as Spline mode but with a different algorithm to prevent overshooting.
Chart Width: Adjust line width (0 for 2D mode)
Tesselation Width: Set tesselation length in spline modes
Thickness: Adjust line thickness (0 for 2D mode)
Depth: Adjust line depth (0 for 2D mode)
Tesselation Thickness: Tessellate line thickness
Tesselation Depth: Tessellate line depth
Const. Thickness: Builds the geometry with a constant width
Miter: Applies a miter cut-off to avoid huge peaks for small data point angles.
Selection: Specify the Start- and Stop-type. Relative: 0%: 100%. Absolute: depends on your specified data. ID: Value ID starting from 0
Start%, abs,: Graph’s starting point
Stop%, abs,: Graph’s stop point
Reposition Start: Translates the whole chart always to the same starting point
Bevel: Activates Bevel mode
Bevel Start: Chamfer start
Bevel Stop: Chamfer stop
Bevel Size%: Adjusts bevel’s size from 0 to 100
Bevel Steps: Sets roundness via the number of segmentation steps
Note: A chamfer is a beveled edge connecting two surfaces.
RelativeMapping: Stretches texture to fit graph length
Pos. Container: Translates every child container to a bar’s top
Container Offset: Adds a certain offset to each container
Value Dependent Pos.: Translates the container above or below the line in dependency on the data values
Container Offset Z: Adds a Z axis offset to each container
Center Container: Centers each translated container
Pointer: You can use a container as a pointer and move it along the chart’s shape
Container: This container represents your pointer
Selection: Specifies the position-type. Relative: 0%: 100%. Absolute: depends on your specified data. ID: Value ID starting from 0
Position%, abs,: The pointer is translated by this parameter
Offset: Adds an offset to the container’s position
Normal Offset: Rotates the offset so that it is perpendicular to the chart’s surface
Rotate: Rotates the container in dependency on the chart’s shape
Offset Z: Adds a Z axis offset to the pointer
Center Container: Use the container’s center for translation and rotation
Low Pointer: Activates the low pointer
Container: Choose a container for the pointer
High Pointer: Activates the high pointer
Start Pointer: Activates the Start Pointer
Stop Pointer: Activates the stop pointer
To Create a Line Chart
Create a new group and add the Line Chart plug-in to it.
Open the Transformation Editor and set Position X and Y to -100.0 and Rotation Y to -25.0.
Add a material and/or a texture to it.
Open the Line Chart editor and set the following parameters:
Set Shared Mem. to Inactive
Set the following DataY values: 10,20,30,20,50,60,80,45,20
Set Line Type to Spline
Set Chart Width to 250.0
Set Depth to 10.0
Enable Bevel, Bevel Start, Bevel Stop
Set Bevel Size% to 100.0
Set Bevel Steps to 10.0
