Click the Scene Editor buttons once to enable the features, click them again to disable.
Reset: Set the Viz Artist layout to default size
Camera Selection: See Camera Selection
Layer Manager: Show or hide the Layer Manager (see Layer Manager)
Snap: Takes a snapshot of the current content in the Scene Editor (see Snapshot )
Post-Processing: Enables rendering of advanced post-processing effects, such as Depth of Field or Lens Distortion, in the scene editor window. Under normal operation, these effects are only rendered in On Air Mode
Key Preview: Activates the preview of the key signal
Normal Vertices: Shows the normal vertices. For example, it is practical to use this feature when the lighting is not reflected in the required manner. Enabling this feature shows the vertices as purple handles. These handles makes it easier to predict how the light will be reflected
Events: Enables the handling of interactive script/plug-in events. Interactive scripts and plug-ins are those related to mouse or keyboard actions
Title Area: Shows the title area as the outline of a light blue rectangle in the Scene Editor
Tip: The size of the title area can be defined under the Rendering Panel scene settings.
Safe Area: Shows the safe area as the outline of a green rectangle in the Scene Editor
Tip: The size of the safe area can be defined under the Rendering Panel scene settings.
Key: Shows what the key output will look like
Wire Frame Mode: Renders the scene in wire frame mode
Bounding Box: Enables the bounding box visualization for the selected Container
Performance Bar: Shows the Performance Bar
Grid: Opens the Grid Tool-bar
