Text FX Scale
The Text FX Scale plug-in allows you to create a scaling animation of the characters.
Text FX Scale Properties
Anchor Horizontal: Sets the anchor point for the characters on the horizontal plane.
Anchor Vertical: Sets the anchor point for the characters on the vertical plane.
Use Axis: Defines on which axis or axes the characters scale.
Lock Axis: With this option enables the Begin- and End scaling are the same for all the axes. If you disable the parameter, Begin and End must be set for all the axes individually.
Begin: Sets the initial size of the characters.
End: Sets the ending size of the characters.
