Control Condition
With the Control Condition plug-in action can be triggered based on the input given in a tab-field with the same field identifier.
Control Condition Properties
Input Value: Show the current input value to the plug-in
Format: Set the format for the input value that it should conditionally trigger on
Condition: Set the type of condition if Format is set to number
Arguments: Set the arguments for the conditional operation
Action Type / Action: Set the action that is to be performed when the condition is met. It can be a control object command like “ON 2 SET mytext” or a Viz Engine command prefixed by a zero and a space
Use Else Commands: When enabled, an else action will be triggered when the input data falls within the conditions
Else Action: Sets the else action that will be triggered when the input data does not fall within the conditions
Example Actions
Actions can be Control Object commands in the form like this:
“ON
2
SET Mike Johnson”
or commands like:
0
RENDERER*STAGE START
Viz Engine commands must be prefixed with a zero followed by a space. This is to enable the plug-in to recognize that the command should be interpreted as a Viz Engine command.
