These are some of the highlights, alongside a vast number of smaller improvements listed in the release notes.
Gaussian Splatting - Reality, Rendered in Real Time
Photorealism used to be a trade-off: weeks of modelling, or "close enough." Gaussian Splatting in Viz Engine removes it. Instead of rebuilding a location, you capture it. In virtual studios, set extensions and backdrops stop looking rendered and start looking photographed — holding their perspective and parallax under a moving tracked camera. In augmented reality, the payoff is the reverse: AR elements finally share the visual language of the real footage beside them, and the illusion holds. Capture instead of model. Photoreal by origin. Real time, on air. Capture once, reuse everywhere. |
Introducing Maps - Every story happens somewhere
Maps in Viz Engine put the whole planet inside your graphics — live, navigable, and styled like everything else you put to air. Not a still someone ordered this morning. Not a browser bolted onto a texture. A real map, rendered in the scene, that you can fly. Pick a place and go. The camera dives from orbit to a rooftop in one unbroken move, your graphics stay pinned to the ground beneath it, and the whole thing lights and composites with the rest of your design because it is part of your design. |
Get started - Introducing Template Library
Viz Artist now includes a Template Library, available from the Templates tab of the Welcome Screen. |
New Logicmaker
Build, preview and check complex Transition Logic pages right inside Viz Artist, in a fast native panel connected directly to the engine. Layers and states at your fingertips. Click a state to take it animated, |
Viz Engine | Viz Artist | Integrations |
