Viz Mosart User Guide
Version 4.1 | Published July 09, 2021 ©
Audio Countdown
images/download/attachments/41792059/image2019-6-28_13-35-2.png
  • Audio file directory: Tells Viz Mosart where to find the audio countdown files. They must be in PCM WAV format (16 bit, 48 kHz), and follow this naming standard:
    • 60_sec
    • 30_sec
    • 10_sec
    • 5_4_3_2_1
These are only examples; the Viz Mosart GUI countdown feature accepts and plays any file on the format above. Thus, a file named 47_sec is played when 47 seconds remain of a given event if that is desired.
Note: For setting-up your Timing Display, see the section Timing Display.
For the countdown to next break feature, the naming standard is:
    • 180_sec_Next_Break
    • 120_sec_Next_Break
    • 60_sec_Next_Break
    • 30_sec_Next_Break
    • 10_sec_Next_Break
    • 5_4_3_2_1_Next_Break
  • Countdown FLOAT templates: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 3 minutes, 2 minutes, 1 minute, 30, 10 and 5 seconds remain until an adlibpix\float element with server\video content.
  • Countdown BREAK templates: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 3 minutes, 2 minutes, 1 minute, 30, 10 and 5 seconds remain until a designated Break line.
  • Countdown PACKAGE templates: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 3 minute, 2 minutes, 1 minute, 30, 10 and 5 seconds remain of the Package template.
  • Countdown story duration: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 3 minute, 2 minutes, 1 minute, 30, 10 and 5 seconds remain until the next story.
  • Count down to autostart rundown: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 3 minute, 2 minutes, 1 minute, 30, 10 and 5 seconds remain until the rundown will autostart.
  • Countdown LIVE story duration: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 1 minute, 30, 10 and 5 seconds remain until the editorial duration end of a live story.
  • Countdown to next BREAK template: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 3, 2 and 1 minute, as well as 30, 10 and 5 seconds remain until the next break.
  • Countdown VOICE OVER templates: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 1 minute, 30, 10 and 5 seconds remain of voiceover templates.
  • Offset countdown to next break: Defines an offset in seconds for the countdown to next Break feature.
  • Enable audio countdown: Plays audio when counting down.
