Viz Mosart User Guide
Version 4.1 | Published July 09, 2021 ©
On Air Shortcut Operations
To speed-up access to operations defined in a template, you can assign them to Viz Mosart shortcut key, by drag and drop.
images/download/attachments/50599063/image2019-8-21_22-35-7.png
When templates are saved to buttons, all their secondary items, including lower thirds and audio files are added too.
To Add a Template Element to a Keyboard Shortcut Button
  1. From the Media Pool, drag an element from the Asset, Favorites or the Quick Access tab.
  2. Drop on a selected Viz Mosart shortcut key.
The selection is saved in your keyboards setup.
To Clear a Template Element from a Keyboard Shortcut Button
  1. Right-click on the button you wish to clear.
  2. Depending on the defined content either:
    1. From the context menu, choose Clear.
    2. Where secondary items are included, choose Clear sub items.
    3. Where NCS-bound keys are included, reset them to their original state by choosing Reset.
See also: Media Pool and General Settings.
