Viz Mosart User Guide
Version 4.1 | Published July 09, 2021 ©
Keyboard Shortcuts
The Shortcut Keys area displays any configured shortcut keys and by default is situated across the bottom of the Viz Mosart GUI.
Keyboard combinations can include Ctrl, Alt and/or Shift to present separate keyboard shortcuts.
images/download/attachments/81467812/image2021-3-23_7-33-21.png
Button State
Several status conditions are included on each button.
images/download/thumbnails/81467812/image2021-3-23_7-35-43.png
Button key: The text under the button displays the key that can be pressed to take the button.
Text: The text on the button shows the text entered in the keyboard editor. Alternatively, if button is bound to NCS content, it may show the slug from the NCS content.
Arrow mark: The arrow in the lower right corner indicates that the button definition is bound to NCS content.
Color: Template shortcuts use the color code as the template it invokes. Other shortcuts use gray background.
Dimmed: A colored button with dimmed state is awaiting NCS content, but has not yet received any. A button does not work when dimmed.
This section contains:
