Viz Mosart User Guide
Version 4.1 | Published July 09, 2021 ©
Recalling a Workspace/Keyboard Layout by Control Command from a Template
A work space and keyboard layout can be recalled with a control command. This control command can be added to a template.
This could be, for example, a BREAK that is invoked at the beginning of a show.
images/download/attachments/58336779/image2019-11-11_9-16-14.png
  1. In AVAutomation, select Template Editor.
  2. From the Template properties dialog, select the Control Commands tab.
  3. Under the Command column drop-down menu, select GUI.
  4. Under the Value column drop-down menu, select WORKSPACE.
  5. In the Parameter column, enter the name of the Workspace (the naming must exist in the Viz Mosart UI).
