Viz Licensing Administrator Guide
Version 3.0 | Published September 14, 2023 ©
Getting Started
Before Installation
  1. Start the CodeMeter Control Center and click the WebAdmin button. The WebAdmin page will open in your browser.
  2. Click Configuration.
  3. Note down the entries in the CodeMeter Server Search List, including the IP address.
During Installation
During installation, you will be prompted about which features to install. For the "Automatic server search" feature, select "Entire feature will be unavailable". The rest of the features should be left at their defaults.
After Installation
  3. Check the Server Search List for an entry named "Automatic server search (255.255.255.255)".
  4. If you find the entry on the list, click on the green trashcan icon on the same line to delete it.
  5. If the entries that you noted down before the installation are missing from the list, add them.
  6. Apply the changes.
