Version 3.14 | Published July 22, 2019 ©
Lens Flare Geometries
The following lens flare plug-ins are simply different shapes for the composition of final lens flare effects. Each has its own parameters to define its appearance.
pxLensGlowBall
pxLensGlowSpikes
pxLensPolyitem
pxLensRandomPoly
pxLensSpark
pxLensStripes
Each plug-in can take on very different appearance depending on how the parameters are adjusted. The best advice for working with these plug-ins is to simply play around with the parameter configurations. The following example shows varying manifestations of the pxLensRandomPoly.
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> PixelFX
