Configuring Import and Update Folders for Network Drives
A Windows service does not have access to network drives mapped with aliases such as M:\ when mapped using a regular domain user.
The following procedures describe how to configure this solution's components to use network drives for playlist imports and updates when running Media Sequencer as a Windows Service.
To set playlist imports and update destination path for schedule files
Start Viz Channel Branding Client in Scheduling mode.
Open the Configuration settings.
Click Channel Settings > Import/Export Settings > General Settings.
Set the Destination path for the schedule files to import or update.
Note: For this case network paths, such as UNC paths (for example, \network\...) are supported; however, mapped drives are not.
To enable automatic import
Click Global Settings > Import/Export settings > Automatic Import.
Set:
- Automatic import interval
- Playlist importer folder path
- Playlist importer log level
To configure Media Sequencer network authentication
In Windows, click Start.
Open the Control Panel, select System and Security > Administrative Tools.
Open Services.
Select and right-click the Vizrt Media Sequencer service.
Select Properties.
Select the Log On tab:
Select the This account radio button.
Enter a username and password that has access to the network share you want to connect to.
Apply and click OK.
Note: If Vizrt Media Sequencer service is already running, please restart the service for the new settings to take effect.
Troubleshooting
Microsoft Excel schedule files cannot be imported
Note: Microsoft Excel and other Microsoft Office applications are not designed to be run as a server application, and Microsoft does not support this usage.
Create a folder named Desktop in the following location:
32-bit systems: C:\Windows\System32\config\systemprofile
64-bit systems: C:\Windows\SysWOW64\config\systemprofile
For more information, see the following knowledge base article on Arcana Development and/or the following Microsoft knowledge base article on Considerations for server-side automation of Office.
