GET All Machine Addresses under Channel
Returns a list of machine addresses for this Channel.
Syntax
GET /config/channels/{channel}/machineaddressesRequest
GET /config/channels/Test/machineaddresses HTTP/1.1Response - List of machine addresses
HTTP/1.1 200 OKContent-Type: application/vizrt.promoserver+xml; type=machineAddressesList<promoserver:machineAddressesList xmlns:promoserver="http://www.vizrt.com/promoserver"> <promoserver:machineAddress> <promoserver:refLink rel="self" type="application/vizrt.promoserver+xml; type=machineAddress" href="http://localhost:9980/config/channels/Test/machineaddresses/localhost" /> <promoserver:refLink rel="edit" type="application/vizrt.promoserver+xml; type=machineAddress" href="http://localhost:9980/config/channels/Test/machineaddresses/localhost" /> <promoserver:refLink rel="status" type="application/vizrt.promoserver+xml; type=machineAddressStatus" href="http://localhost:9980/config/channels/Test/machineaddresses/localhost/status" /> <promoserver:name>localhost</promoserver:name> </promoserver:machineAddress> <promoserver:machineAddress> <promoserver:refLink rel="self" type="application/vizrt.promoserver+xml; type=machineAddress" href="http://localhost:9980/config/channels/Test/machineaddresses/backuphost" /> <promoserver:refLink rel="edit" type="application/vizrt.promoserver+xml; type=machineAddress" href="http://localhost:9980/config/channels/Test/machineaddresses/backuphost" /> <promoserver:refLink rel="status" type="application/vizrt.promoserver+xml; type=machineAddressStatus" href="http://localhost:9980/config/channels/Test/machineaddresses/backuphost/status" /> <promoserver:name>backuphost</promoserver:name> </promoserver:machineAddress></promoserver:machineAddressesList> Error Response - Channel not found
HTTP/1.1 404 Not FoundContent-Type: application/xml; charset=utf-8 <string xmlns="http://schemas.microsoft.com/2003/10/Serialization/">Element Test could not be found</string> Disallowed Actions
This end-point does not allow PUT or DELETE, and will return a 'HTTP/1.1 405 Method Not Allowed'.
