Merging Fields
The ability to join fields is to be able to right in the Mapping Table for an import module be able to store info and instantly re-use it to another mapped variable. By default the variable Begin_at is mapped up to be a merge of Date and Time field, with a value-separator.
Example
date = /date/
time = /time/
begin_at = @dateT@time
IMPORTANT! The merging field must be located in the table after its parts-fields.
Example 1 for Fixed Width Any Text Import Type
  • StartHour = $L(1,2)
  • StartMin = $L(3,4)
  • StartSecond = $L(5,6)
  • Begin = @StartHour:@StartMin:@StartSecond
Example 2 for Delimited Any Text Import Type
  • StartHour = $L(4)
  • StartMin = $L(5)
  • StartSecond = $L(6)
Example 3 for Any XML Import Type
This example shows time read in a format HH-MM-SS-FF from an entry /begin_time/time/.
  • TheStartTime = /begin_time/time/
  • StartHour = &(TheStartTime,”-”,1,1)
  • StartMin = &(TheStartTime,”-”,2,1)
  • StartSecond = &(TheStartTime,”-”,3,1)
  • StartFrame = &(TheStartTime,”-”,4,1)
  • Begin = @StartHour:@StartMin:@StartSecond:@StartFrame
