 Viz Social User Guide
Version 1.1 | Published January 26, 2022 ©
Interval Configuration
Once all data sets have been added to a Report, the Report can be tuned, and the data is ready for interpretation. The most important thing to consider is the time window. By default, each Report shows the evolution over time of the data set for the last two hours with a resolution of ten minutes. Users can choose their preferred time interval, either as a relative indication (the last … minutes/hours/days/weeks) or as an absolute time interval with fixed start and end times.
The resolution can be chosen so that detailed fluctuations are visible or not. The system has a configurable maximum number of points so sometimes smaller resolutions are automatically disabled because they would result in too many data points in the Report. Resolutions and time intervals are applied to all data sets in a Report at the same time.
