 Viz Social User Guide
Version 1.1 | Published January 26, 2022 ©
Text Highlight
The Text Highlight plug-in recognizes certain characters and allows color changes to any word containing that character (for example: #tags @User http://) when placed on a text container the plug-in.
Note: You must send text to the text property of this plug-in using ControlParameter.
Note: This plug-in is located in: Plugins -> Container plug-ins -> SocialTV
Text Highlight Properties
Coloring
When Text Highlight is placed on a text container, the plug-in recognizes certain characters and lets you change the color of any word containing that character (e.g., #tags, @User, http://).
Emoji
-     Emoji: Toggles whether to highlight emoji content.
-     Images: Default/Custom. -     When using default the plug-in uses the images located in C:\Program Files\Vizrt\VizArtist\plugin\data\TextHighlight\72x72.
-     When using custom the user defines a path to their own images. Note: The custom path should be accessible to all machines running Viz Engine, including Viz Trio and Preview Engines.
-     Characters Folder:
-     Word Folder: Defines a folder of images containing words that should be replaced by emojis.
-     Size:
-     Ignore List: Defines a list of characters that should be ignored when replacing with emojis.
-     Word List Separator: Sets the character to be used as a separator of the list of words to replace by emoji.
-     Word List: Defines a list of words to be replaced by emojis.
-     Print Codes:
-     Scan Folders:
-     Update Word List:
Text FX
The Text FX option allows users to apply similar effects as Text FX plug-ins when using emojis.
Example
