![](assets/images/logos/VizWorldLogo.png)
Viz World User Guide
Version 22.0 | Published December 15, 2022 ©
Getting Started
Once you have the Viz World Client installed, you can start the Map Designer and connect to the Viz World Server. Once connected you are able to open existing design projects, use existing templates, create new templates from existing templates, or create a template from scratch using a blank template.
To Start the Map Designer
The Map Designer can be started from the desktop or start menu (i.e., Viz World Design Client), or from the installation directory (MapsDesignClient.exe):
32-bit system: C:\Program Files\vizrt\Common\Maps
64-bit system: C:\Program Files (x86)\vizrt\Common\Maps
To Connect to Viz World Server
Start the Map Designer.
Click the Settings button, located on the toolbar.
Set the Viz World Server hostname. If not specified, the Map Designer connects to localhost.
Click Save.
To Create a Map Template
Select one of the following options:
Open Project: Opens an existing project.
From Template: Starts a new project based on a selection of default stylesheets.
From Existing: Starts a new project based on an existing project.
Blank: Starts a new project.
