![](assets/images/logos/VizWorldLogo.png)
Viz World User Guide
Version 22.0 | Published December 15, 2022 ©
Software Compatibility
To run the Viz World Client and Server, the following software is required:
Viz World Client (Map Editor) version 22.0.
Viz World Server 22.0 (It is recommended to install the server on a separate machine).
Installing Viz World server and Viz World client on separate machines is recommended.
Viz World database version 22.0
Viz World database is recommended to be installed on the same machine as Viz World Server for easier configurations.
Microsoft Visual C++ 2010 Redistributable Package.
Microsoft Visual C++ 2019 Redistributable Package.
Microsoft .NET Framework 4 or later is required for the Map Designer, Map Builder, and World Map Editor.
Running any of the installers version 22.0 will install all the required software listed above which should not be uninstalled.
Viz World 22.0.0 was tested with:
Viz Engine 5.0.0
Viz Pilot 8.8.0
Viz Pilot Edge 2.4.0
Viz Pilot Data Server 8.9.1
Viz Trio 4.1.0
