![](assets/images/logos/VizWorldLogo.png)
Viz World User Guide
Version 22.0 | Published December 15, 2022 ©
Project Templates
It is good practice to place all template (TPL) files in a single static location. The recommended location is:
32-bit: C:\ProgramData\Curious Software\Curious World Maps\Users\Default\Projects
64-bit: C:\ProgramData\vizrt\Viz World\Users\Default\Projects
This folder and any sub-folders are automatically scanned for TPL files when the Map Server is launched.
Note: The template location should be exactly the same on Viz World Server and any Viz World Classic design systems. If the paths are not identical, it may break the link to any image elements (e.g., Markers).
To Open a Project Template
Select Open... (CTRL + O) from the File menu.
Select Project Template (*.tpl, *.tpt, *.cgt) from the Files of type drop-list.
Select the template file and click Open.
To Save a Project Template
Select Save (CTRL + S) from the File menu.
Select Project Template (.tpl) from the Save as type drop-list.
Enter a filename, and click Save.
