Dell Precision R3930
This section describes the specification and PCI board layout of a Dell R3930 machine with the different cards provided by Vizrt.
Default Hardware
Server 1RU
OS: Windows 10 IoT Enterprise LTSC 2019
CPU: 1x Intel Xeon E-2186G 6-Core
RAM: 32 GB DDR 4 (4x 8GB)
1st SSD: 256 GB S-ATA SSD
2nd SSD: 512 GB M.2 on Mainboard
RAID Controller: Intel Onboard
Hot Plug Power Supply:2x 550W
Connectors
         Front connectors  |
         Back connectors  |
         1. HDD activity light 2. Hard drive (4x2.5") 3. Audio jack 4+5. USB 3.1 (Type C) 6. SD card reader 7. Power button/power light 8. Information tag  |
         9. PCIe x8 or unused if 10. is PCIe x16 10. PCIe x16 or PCIe x8 if 9. is used 11. PCIe x4 slot 12. USB 3.1 (Type C)/iGFX DisplayPort (2x) 13. Remote power switch connector 14. Serial port 15. 10G RJ-45 Ethernet 16. 1G RJ-45 Ethernet 17. Redundant dual 550W power supplies  |
PCI Configuration with P4000 or P6000
         Slot  |
         Usage  |
         Slot 1  |
         GPU  |
         Slot 2  |
         unused, otherwise GPU would not run PCIe x16  |
         Slot 3  |
         Matrox DSXLE4 or other PCIe card  |
PCI Configuration with P2000
         Slot  |
         Usage  |
         Slot 1  |
GPU (Runs at PCIe x8 Speed if Slot 2 is used)
         Slot 2  |
Sealevel GPI, Plura Timecode, Bluestorm RS422
         Slot 3  |
PCI Configuration with Onboard GPU (Intel HD620)
         Slot  |
         Usage  |
         Slot 1  |
         Sealevel GPI, Plura Timecode, Bluestorm RS422  |
         Slot 2  |
         Slot 3  |
Note: Intel HD620 onboard GPU uses USB-C type connector. In most cases an Adapter is required to connect a Monitor.
BIOS Settings
During Post, press F2 to get access to the BIOS Setup.
General - Advanced Boot Options – uncheck Legacy Option ROMs
Performance - Intel Speed Step - uncheck “Enable Intel Speed Step”
Performance - C-States Control - uncheck “C States”
Thermal Configuration – CPU Zone: set speed to 20%
Thermal Configuration - PSU and PCIe Zone: set speed to 20% If working under high ambient temperatures, fan speed may be set to a higher value.
Note: Certain third party vendor drivers require secure boot to be disabled to install properly.
