SNMP Viz Engine OIDs
This document lists all available OIDs for Viz Engine. N represents the current channel, that is 1 is for Viz Engine Channel 1 (first instance).
Viz Engine OIDs
         Value OID  |
         Description  |
         Type  |
         Info  |
         27566.1.1.1.N.1  |
         Ready For Connect  |
         TruthValue  |
         Viz Engine is initialized and running (On Air or Off Air).  |
         27566.1.1.1.N.2  |
         On Air  |
         TruthValue  |
         Viz Engine is On Air.  |
         27566.1.1.1.N.3  |
         Connected To Db  |
         TruthValue  |
         Viz Engine is connected to Viz Graphic Hub.  |
         27566.1.1.1.N.4  |
         Post Render Mode  |
         INTEGER normalmode(0), postrendermode(1)  |
         Post render mode active.  |
         27566.1.1.1.N.5  |
         NLE Mode  |
         INTEGER normalmode(0), nlemode(1)  |
         NLE mode active.  |
         27566.1.1.1.N.6  |
         Current Frame Rate  |
         Integer32 (0..10000)  |
         Current frame rate.  |
         27566.1.1.1.N.7  |
         Retrace Counter  |
         Integer32 (0..65536)  |
         Changing number when the engine is rendering.  |
         27566.1.1.1.N.8  |
         Viz Engine Version  |
         OCTET STRING (SIZE (0..128))  |
         Version string.  |
         27566.1.1.1.N.9  |
         System ID  |
         Dongle ID.  |
         27566.1.1.1.N.10  |
         Computer Type  |
         INTEGER irix(0), video(1), panasonic(2), pc(3), twc(4), sgipc(5), chyron(6), unknown(7)  |
         27566.1.1.1.N.11  |
         TCP Port  |
         TCP command port, 6100 or similar.  |
         27566.1.1.1.N.12  |
         Genlock Status  |
         INTEGER ok(0), wrongformat(1), bad(2), droppedframes(3), unknown(4), notavailable(255)  |
         Genlock status.  |
         27566.1.1.1.N.13  |
         Video In 1 Status  |
         Video input status.  |
         27566.1.1.1.N.14  |
         Video In 2 Status  |
         27566.1.1.1.N.15  |
         Video In 3 Status  |
         27566.1.1.1.N.16  |
         Video In 4 Status  |
         27566.1.1.1.N.17  |
         Video In 5 Status  |
         27566.1.1.1.N.18  |
         Video In 6 Status  |
         27566.1.1.1.N.19  |
         Video In 7 Status  |
         27566.1.1.1.N.20  |
         Video In 8 Status  |
         27566.1.1.1.N.21  |
         Clip 1 Status  |
         Clip status.  |
         27566.1.1.1.N.22  |
         Clip 2 Status  |
         27566.1.1.1.N.23  |
         Clip 3 Status  |
         27566.1.1.1.N.24  |
         Clip 4 Status  |
         27566.1.1.1.N.25  |
         Clip 5 Status  |
         27566.1.1.1.N.26  |
         Clip 6 Status  |
         27566.1.1.1.N.27  |
         Clip 7 Status  |
         27566.1.1.1.N.28  |
         Clip 8 Status  |
         27566.1.1.1.N.29  |
         Texture Memory Free  |
         Integer32 (0..2147483647)  |
         Texture memory available in KB.  |
         27566.1.1.1.N.30  |
         Texture Memory Total  |
         Total texture memory in KB.  |
         27566.1.1.1.N.31  |
         Texture Memory Used  |
         Integer32 (0..100)  |
         Texture memory used (percentage).  |
         27566.1.1.1.N.32  |
         Renderer Scene Front  |
         OCTET STRING (SIZE (0..1024))  |
         Scene name.  |
         27566.1.1.1.N.33  |
         Renderer Scene Middle  |
         Scene name.  |
         27566.1.1.1.N.34  |
         Renderer Scene Back  |
         Scene name.  |
         27566.1.1.1.N.35  |
         Post Scene Front  |
         Scene name.  |
         27566.1.1.1.N.36  |
         Post Scene Middle  |
         Scene name.  |
         27566.1.1.1.N.37  |
         Post Scene Back  |
         Scene name.  |
         27566.1.1.1.N.38  |
         Retrace Counter Moving  |
         TruthValue  |
         Computed flag; true if the retrace counter changes. Can be possibly used to detect hanging renderer.  |
Viz Engine Trap OIDs
On change of some of the important properties a trap (notification) is generated too. This way the monitoring system which is polling the values at regular intervals gets the change immediately. Persisting “failed” values trigger repeated traps.
         Trap OID  |
         Description  |
         Value OIDs Included  |
         Info  |
         27566.1.1.1.N.0.1  |
         Ready For Connect Changes  |
         27566.1.1.1.N.1  |
         Sent when state changes or periodically if value is false.  |
         27566.1.1.1.N.0.2  |
         On Air State Changes  |
         27566.1.1.1.N.2  |
         Sent when 27566.1.1.1.N.2 is true and state changes or periodically if value is false.  |
         27566.1.1.1.N.0.3  |
         Db Connection State Changes  |
         27566.1.1.1.N.3  |
         Sent when 27566.1.1.1.N.3 is true and state changes or periodically if value is false.  |
         27566.1.1.1.N.0.4  |
         Genlock State Changes  |
         27566.1.1.1.N.12  |
         Sent when 27566.1.1.1.N.12 is true and state changes or periodically if value is not 0.  |
         27566.1.1.1.N.0.5  |
         Texture Memory Changes  |
         7566.1.1.1.N.29-31  |
         Sent when 27566.1.1.1.N.29-31 is true and state changes or periodically if value is < 10000 KB (hardcoded).  |
         27566.1.1.1.N.0.6  |
         Retrace Counter Changes  |
         27566.1.1.1.N.38  |
         Sent when 27566.1.1.1.N.38 is true and state changes or periodically if value is false.  |
         27566.1.1.1.N.0.7  |
         Renderer Front Scene Changes  |
         27566.1.1.1.N.32  |
         Sent when 27566.1.1.1.N.32 is true and state changes.  |
         27566.1.1.1.N.0.8  |
         Renderer Middle Scene Changes  |
         27566.1.1.1.N.33  |
         Sent when 27566.1.1.1.N.33 is true and state changes.  |
         27566.1.1.1.N.0.9  |
         Renderer Back Scene Changes  |
         27566.1.1.1.N.34  |
         Sent when 27566.1.1.1.N.34 is true and state changes.  |
