Pinnacle Targa 3200
Pinnacle Targa 3200 was Vizrt’s standard card for SD Viz systems until 2007, and was typically used with IBM ZPro 6221, IBM Z-Pro 6223 and HP xw8200.
Configuration History
         Driver  |
         Revision  |
         CODI v2.42  |
         3213. Revision 3213 crashes the machine when used with CODI v2.41rc13.  |
         CODI v2.41rc13  |
         3212, 3214. Installation of CODI Compatibility Patch for revision 3214 is no more required.  |
         CODI v2.42  |
         3212, 3213, 3214. Installation of CODI Compatibility Patch is required.  |
         CODI v2.2 RC4  |
         3212, 3213  |
